Results 1 to 10 of 11
Thread: Nested Family hidden in Legend Component View
    October 14, 2011
    Boston, MA
    222
    01:44 PM
    It appears that it is a commonly known issue with Revit that families nested beyond two degrees of seperation (a familiy, within a family, within a family), will not appear when using Legend Component views. The problem is that all our windows are made this way and we have a deadline . I would just create the Legend Component view of the sub-family since we hide all our casing anyway in window elevations but these sub-families are driven by instance parameters which do not track through the Legend Component system.
    Does anyone make their windows this way and get them to work with Legend Component Views?
    This is the complete window family:
Name:	parent family.PNG
    Nested within the jamb we model the window sash (easy to swap styles and organizes parameters)
    Finally we nest in a parametric 'grid' that generates glass and muntin patterns (2x2,2x3,4x4 pattern etc..)
    when creating a Legend Component view of the Front Elevation this is what I see (no parametric glass and muntin family)
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,477
    12:44 PM
    I use a documentation phase and model views, not legends - there are just too many restrictions on legend views. Especially if you are on a deadline that might be the fastest option.
    2,665
    04:44 AM
    I'd rather use drafting views than have to deal with legend components. But I use future phase model views.
    October 14, 2011
    Boston, MA
    222
    01:44 PM
    thank you for the quick help, jmk and elton. you both use phases and model views, does this mean a phase for each window? or do you simply hide the other windows or elements in view so that only the window you want is shown in elevation? What if we would like to see the same window through multiple phases? for example we already use phases to create multiple drawing sets in a single project (City Submittal Set, CD set, etc..) is it possible to show the same window through both while being on its own documentation phase. I'm fairly new to trying a project this way so please excuse all the questions
    thanks!
    3,072
    01:44 PM
    December 31, 2012
    NM, USA
    1,477
    12:44 PM
    What we do is have a phase (earlier means you need to demo the items, later you don't, both work as long as your view settings are right). In that phase we place an instance of each element type we want to see in the legend - doors, windows, etc. We then create views that look at that phase, and place the view on the sheet (using dependent views if the legend needs to be on multiple sheets) and tag/annotate them as needed. Using the documentation phase allows you to put them in a line, and you only need a couple views to get everything.
    10,530
    01:44 PM
    Earlier means you have to demolish, later means you have to make sure to put it somewhere (physically) that the project won't run over it. As long as you have an area staked out in the template, that can work.
    But there's always a chance a future renovation runs in to it.
    Trade offs, either way.
    Aaron Maller
    Director
    Parallax Team, Inc.
    July 10, 2015
    Boise, Idaho
    738
    12:44 PM
    That's why I place my phased legend items above the maximum allowable height for that zone. The chances of that ever becoming an issue are somewhat less than winning the lottery
    October 14, 2011
    Boston, MA
    222
    01:44 PM
    P.S - does anyone happen to know if the nested objects in legend components issue is resolved in Revit 2018?
    10,530
    01:44 PM
    Nothing has changed in 2018, to the best of my knowledge. I wouldnt expect it to change for 2019, as well, since i dont think Autodesk considers it *broken.* Legend Views are basically ****. I dont use them for anything other than text.
  1. Nested Detail Component in Beam Family
    By GD_ in forum Structure - Family Creation
    Last Post: July 1st, 2015, 06:51 PM
  2. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  3. Nested adaptive component family wont flex in parent family (Revit 2013)
    By Steve_Bennett in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 22nd, 2014, 11:45 PM
  4. Legend Component Straight to Family
    Last Post: July 10th, 2012, 09:24 AM
  5. Legend Component x view range
    By Hugo Tavares in forum Architecture and General Revit Questions
    Last Post: August 11th, 2011, 08:17 PM
