Thread: Hidden lines showing in 3d view
    Junior Member Laggingbehind's Avatar
    November 23, 2017
    North Kent
    5
    06:42 PM
    Another newbie question.... I've created basically an upturned box 1.2mm thick. Near the top I have a inset panel which sits on the inside face of the material thickness. However when I zoom out I can see the line where this panel sits which is a bit of a pain as I dont want it visible. When you zoom in it disappears.... any suggestions would be welcome
    Attached Thumbnails Attached Thumbnails Zoomed in.PNG   Zoomed out.PNG   View form underside.PNG
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    864
    05:42 AM
    It happens with face differences of a few mm.
    November 23, 2017
    North Kent
    5
    06:42 PM
    Thanks mate. will see how much I need to reduce the roof panel back until it dissappears
  1. Slab cut outs not showing as hidden lines
    By edmund in forum Architecture and General Revit Questions
    Last Post: May 27th, 2015, 07:36 AM
  2. Revit Hidden line/Solid view still showing wireframe
    By kranjerj in forum Architecture and General Revit Questions
    Last Post: February 25th, 2014, 02:23 AM
  3. Hidden line view. Hidden lines showing.
    Last Post: July 27th, 2013, 09:12 AM
  4. Hidden lines not showing on small plan views
    By edmund in forum Structure - General Questions
    Last Post: October 31st, 2012, 01:02 PM
  5. Piles not showing hidden lines through structural foundations
    Last Post: June 26th, 2012, 09:13 AM
