Thread: How to Create this Glass Fixture
    March 31, 2011
    62
    03:38 PM
    I am trying to model a glass light fixture to represent the attached picture in order to place in project and render. I need help in how to create the surfaces/forms in REVIT.
    1,380
    09:38 PM
    It is a bit hard to see, but are they plat pieces of glass or are they lens shaped?
    I would go for easy flat pieces of glass, easy to model, for more organic shapes maybe try to go trough Fusion 360?
    March 31, 2011
    62
    03:38 PM
    These are organic shapes. Need to be able to model and assign glass material to them so revit can render
    Coeur d Alene, ID
    4,853
    12:38 PM
    Looks like it is 3 separate fixtures, just set at different heights. I'd go that route instead of trying to build just one. As for the lens, I would just keep it simple and build a round extrusion then cut a void to it.
    Then there will be the folks that can make it analytical and link it to Dynamo and make some far out model that is way more that is needed for the project...but it will look way cool.
  1. Glass Symbols on Glass Elevations
    By kamranmirza in forum Architecture and General Revit Questions
    Last Post: September 4th, 2018, 05:07 AM
  2. glass canopy help
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: August 5th, 2013, 02:27 PM
  3. Glass facade
    By Aussiejayne in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 7th, 2012, 12:44 PM
  4. U-value Glass
    By Camille in forum Architecture and General Revit Questions
    Last Post: October 14th, 2011, 08:53 PM
  5. 2D Transparent Glass
    By mark b in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 07:15 PM
