Results 1 to 10 of 10
Thread: Extrusion & Sweeps - Has something changed?
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    07:44 PM
    I'm not sure if I am doing something wrong or if Revit has changed in the last few years. When creating extrusions and sweeps in sketch mode, I remember being able to enter offset values using pick lines and selecting existing reference planes. When a parameter value that flexed these ref planes was changed, the extrusion or sweep flexed as well. I've just been repeating the same behaviour in 2018.2 and the extrusions and sweeps I create refuse to move when changing the parameter. I'm almost certain I was told on here that about this behaviour, yet it doesn't seem to work any more
    December 11, 2013
    464
    07:44 PM
    I just found the thread, https://www.revitforum.org/architect...ow-family.html
    Has anyone found the same experience I am now getting?
    883
    04:44 AM
    I can use a pick line with an offset but I dont believe I can lock the offset value. However I can constrain my sketch using dimensions in the sketch mode and lock them. But lock automatically while using an offset I dont believe so. Without an offset yes I can constrain to the picked line automatically.
    December 11, 2013
    464
    07:44 PM
    That's the thing, you never had to lock any value, there was this non-visible link where the offset value you entered was stored internally. I remember last doing it with 2014 but it seems this behaviour is no longer permitted and I now have to add dimensions to a ref plane in the sketch. In my view this is a quite disappointing change from Autodesk as it was a really elegant method to use when creating multiple extrusions and sweeps, all relative to a single ref plane, all of which moved whenever the ref plane was flexed whereas now you either add a whole lot more ref planes or dimension and lock in sketch mode .
    10,530
    01:44 PM
    I never replied on automatic constraints in any way, even when they seemed to flex automatically. It was never "assured" they would work reliably.
    Aaron Maller
    Director
    Parallax Team, Inc.
    2,665
    04:44 AM
    I would prefer no automatic constraints whatsoever. If i want something constrained i can lock it myself. Weird stuff happens with auto constraints that sometimes takes longer to figure out.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,477
    12:44 PM
    I agree. Revit is terrible at reading my mind, and I spend extra time making sure there aren't automatic references.
    December 11, 2013
    464
    07:44 PM
    I never experienced any problems with them but I guess its likely they would confuse many people, as they did me at first. I'd have liked it was left as user toggle hidden away the options (default set to Off) for those who do want to automatic constraints but I'll just have to get used to busier looking families in the editor.
    10,530
    01:44 PM
    It's not a matter of user confusion: automatic constraints are also autonatically lower priority Tha. Real constraints. So, as I typically have more than one thing moving in more than one direction, they are a really bad idea all around. Because one of them can (and will) "let go" if the line has a relationship to something ELSE other than the original picked line.
    I've never EVER built a family that relied on automatic sketch constraints.
    Aaron Maller
    Director
    Parallax Team, Inc.
    Member duende123's Avatar
    November 20, 2015
    186
    02:44 PM
    holy words!!!! Hallelujah!!!
  1. Integral Sweeps Change Display when Far Clip Changed
    By JayDub in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2016, 04:41 PM
  2. Embedded door panel changed horizontal location when height parameter is changed
    By DavidLarson in forum Architecture - Family Creation
    Last Post: August 10th, 2015, 05:59 PM
  3. Graphic representation of Sweeps... lots of sweeps...
    Last Post: May 5th, 2015, 03:18 PM
  4. Allow the Family host extrusion to move together with void extrusion
    By JiaQing in forum Architecture - Family Creation
    Last Post: March 6th, 2015, 04:21 PM
  5. Behaviour of wall-hosted sweeps has changed in 2015
    By Wes Macaulay in forum Architecture and General Revit Questions
    Last Post: June 11th, 2014, 05:45 PM
