Thread: Box Gutters
    November 22, 2017
    05:44 AM
    Box Gutters
    I am having trouble inserting a box gutter into model. I have tried to create the rectangular gutter in Revit Family Profile and then inserting it into the model. It indicates an error "Cannot create the gutter"
    I have also created it via Revit Family Profile Host and then pick the egde of the 40mm thick roofing, but get the same result.
    Could someone explain so I can continue.
    1,380
    09:14 PM
    Can you post the profile you made?
    A profile need to be a closed loop and have no overlapping or intersecting lines.
    2,665
    05:14 AM
    Firstly, welcome to the forum
    There are a number of things that could be causing this - profile is not a single loop, self intersecting geometry, sketch lines not joining and a gutter will only attach to horizontal roof edges (fascias will work on sloped edges). Also try using the regular profile family template.
    July 10, 2015
    Boise, Idaho
    738
    01:14 PM
    Sloped gutters can be fun. Model in place a roof using a sweep and the gutter profile. Instant gratification followed by much confusion as everybody else wants to know how you did that
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    864
    06:14 AM
    Ive used a lined based generic model.
    November 22, 2017
    05:44 AM
    Box Gutter
    Quote Originally Posted by David_Stewart View Post
    I have modified the 180 (deep) x 600 (wide) box gutter so that there are no non-linked lines as suggested but the gutter operation gets the same error message?
    November 22, 2017
    05:44 AM
    I tried to create the gutter with a lager thickness to ensure closure of the profile and it worked
    Thanks all!
  1. Gutters
    By Minotaur in forum Architecture and General Revit Questions
    Last Post: August 24th, 2015, 05:50 PM
  2. Adjusting gutters
    Last Post: August 7th, 2013, 03:40 AM
