Thread: Creating a 3D View for each level with a corresponding Section box
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    09:41 PM
    I'm trying to generate a section box that is applied to a 3D view that is specific to a level. so if there are 25 levels, there are 25 3D views, and just as example, lets say the section box goes from 0' below the level to 4' above the level. I've managed to create the bounding boxes that are in the appropriate place, but when i try to connect them View3D.SetSectionBox, it's just give a bunch of null, and applying only the first section box to all of the views.
    I think that particular node won't accept lists as input
    I'm planning to use this for coordination views between architecture, structure, MEP, etc, and slice up the 3D views by level.
    September 19, 2015
    163
    05:41 AM
    There is a newer version (a Zero Touch version, I think) of this Rhythm node located in RevitElements / View3D folder that should give you the result you want without further adjustments
    October 11, 2012
    St. Louis
    403
    09:41 PM
    I'm not sure what you mean by Zero Touch. I've updated my Rhythm package and am still getting the same results.
    September 19, 2015
    163
    05:41 AM
    Zero Touch refers to a specific way to create custom nodes. They look like OOTB ones. If you are interested, you will easily find online resources about it, for instance here: Zero-Touch Importing | The Dynamo Primer
    Below is an illustration of what I tried to say. The old node (at left) returns null values but with lacing set to longest, it's doing what I want anyway. The new node does automatically what is awaited. My version of Rhythm is 2017.9.6
    October 11, 2012
    St. Louis
    403
    09:41 PM
    so when i say that I updated my Rhythm package, I meant to say that Dynamo was thinking about updating.. and was really just giving me the old one.. I got the new one in there and it works great.
    October 11, 2012
    St. Louis
    403
    09:41 PM
    Here's my final graph if anyone wants to use it / take it further
    November 7, 2013
    6
    08:41 PM
    Thanks a bunch for sharing ryntau.
  1. Changing Level/Section Heads depending on the view scale
    By vadimfarcas in forum Architecture and General Revit Questions
    Last Post: March 23rd, 2016, 03:24 PM
  2. Creating a section to a level.
    By Andythebear in forum Architecture and General Revit Questions
    Last Post: March 18th, 2016, 09:45 AM
  3. Overhead Lines - Underlay View from Level Differs from Corresponing Level's Plan
    By Limbatus in forum Architecture and General Revit Questions
    Last Post: January 12th, 2016, 01:15 AM
  4. Created Section View. SOME level heads missing.
    Last Post: January 14th, 2014, 04:52 AM
  5. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 17th, 2012, 11:41 PM
