Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Converting a door family to a curtain wall door
    July 10, 2015
    Boise, Idaho
    733
    02:28 PM
    Is there is a relatively easy (i.e. fast) way to turn a door family into a curtain wall door family? I made a bunch of doors similar to Aaron's with all the nested families, shared parameters and time spent. If possible I'd rather not have to make a new door family from the frame inward
    10,511
    03:28 PM
    Not that i know of. And FWIW i had to build them very differently. Constrained different, a few different parameters, and different Frame Families, to be correct for SF/CW applications.
    July 10, 2015
    Boise, Idaho
    733
    02:28 PM
    OK thanks. I thought that would be the case.
    4,415
    09:28 PM
    The only way to do it is to model your children families so that they can be used by both hosting applications from the ground up.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,534
    01:28 PM
    I don't understand this comment, can you expand the thought a bit?? To me, curtain wall doors don't have "children families" except for additive things like door hardware items
    2,658
    01:28 PM
    Children families as in shared nested leaves and frames, I think.
    4,415
    09:28 PM
    Exactly Greg.
    10,511
    03:28 PM
    FWIW I use the same nested shared panels and hardware. If your frames do the actual wall cutting (and have wall frame profiles modeled accurately) they won't be the same for cw, so you'll need different frames.
    Aaron Maller
    Director
    Parallax Team, Inc.
    4,415
    09:28 PM
    I took my doors to v.34 last weekend (!) and have yet to fully implement an approach that caters for both, but I've had planned for another time. With the intent that the frame wouldn't cut, (being more like the panel) - where I'd have a cutting child for basics. I push-down so many parameters from the parent, that it'd just be connecting the two child.
    Tail wags dog? Almost certainly.
    10,511
    03:28 PM
    It wont work, worth a damn.
    Not if you have complex shaped frames that arent simple rectangles. (Partial sidelights, partial transoms, etc). Because its not information "pushing" from the Parent family down to the frame: Its the frames selection making that distinction. Unless you want to end up with a redundant "Cutter selector," which (imvho) would suck.
  1. Insert a door in curtain wall
    By Somaya in forum Architecture and General Revit Questions
    Last Post: October 29th, 2015, 08:37 PM
  2. Curtain wall door
    By constrainmenot in forum Architecture and General Revit Questions
    Last Post: December 17th, 2014, 06:59 PM
  3. Curtain Wall Door
    By gatechrevit in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2013, 07:15 PM
  4. Dimension of Curtain door in Door legend
    By phamtuan in forum Architecture - Family Creation
    Last Post: March 29th, 2013, 04:32 PM
  5. Nested door in curtain wall panel, family
    By Alfienoakes in forum Architecture - Family Creation
    Last Post: July 20th, 2012, 04:24 PM
