Thread: project base point & survey Point
    September 8, 2014
    India
    59
    05:11 PM
    Post project base point & survey Point
    hi,
    Kindly explain the difference between
    1. project base point (Clipped)
    2. project base point (Unclipped)
    3. Survey point (Clipped)
    4. Survey point (Unclipped)
    Mainly I am confusing about the difference between clipped and unclipped state.
    Thanks for guiding me.
    June 21, 2012
    Tours, France
    1,116
    12:41 PM
    Hi Dhilip, that was already discussed in this thread:
    https://www.revitforum.org/architect...vey-point.html
    Regards
    September 8, 2014
    India
    59
    05:11 PM
    hi https://www.revitforum.org/members/andres-franco.html
    it is not clear much confusing.
    Moderator mark b's Avatar
    NSW Australia
    1,436
    08:41 PM
    Try Steve's explaination here
    Autodesk JeffH's Avatar
    807
    06:41 AM
    You can try these 2 topics in the help
    Move Project Base Point
    Help
    Move Survey Point
    Help
    11,001
    05:41 AM
    Don't ever "move" either the PBP or the Survey Point. It you always use acquire, publish, or specify coordinates at a point, you don't have to worry about clipped or unclipped.
    Aaron Maller
    Director
    Parallax Team, Inc.
    3,167
    03:41 AM
    Clipped = changes actual position settings (generally not a good choice)
    Un-Clipped = Changes the symbol position only, does not actually change anything.
    As Aaron wrote, use the specific intended tools for managing coordinates and position and you can (should) ignore and avoid altering the symbols directly. If I decide I want to use the symbols (as useful markers) I only move them un-clipped.
  1. Adjust project base point vs survey point in elevation
    By iru69 in forum Architecture and General Revit Questions
    Last Post: March 13th, 2018, 04:56 PM
  2. Project Base and the Survey Point
    By andreasdraxl in forum Architecture and General Revit Questions
    Last Post: July 4th, 2016, 04:20 PM
  3. Project Base Point | Survey Point | Absolute Elevation Issue
    By siqbal16 in forum Structure - General Questions
    Last Post: March 29th, 2016, 10:16 PM
    Last Post: August 10th, 2015, 12:15 PM
    Last Post: May 25th, 2015, 12:15 PM
