Thread: View Crop Boundaries
    6,233
    01:55 AM
    I'm trying to update my graph to turn off view crop boundaries and have it working except for one part - I can't get the filter to keep interior elevations on while turning off all of the other elevations. Until recently it worked fine so the issue seems to have something to do with either a Dynamo update or a package update (Rhythym or Archi-Labs most likely.)
    Attached Thumbnails Attached Thumbnails ViewCropBoundary-1.PNG   ViewCropBoundary-2.PNG
    Member johnp's Avatar
    March 24, 2015
    157
    10:55 PM
    What does the error say?
    6,233
    01:55 AM
    Dereferencing a non-pointer. Super helpful right?
    2,664
    03:55 PM
    I don't see any custom nodes in this script. And without knowing your Revit properties I'm not sure if your view type or parameter names contain correct values?
    edit. What happens if you use 'all elements of type' node instead of 'view.getbytype'
    March 24, 2015
    157
    10:55 PM
    I think you may be feeding the wrong thing into your "Filter.ByBooleanMask", the output should be an element with an ID and currently it looks like a string.
    June 7, 2011
    8
    01:55 AM
    Our Dynamo guru creates it one for us some time ago.
Name:	2017-06-30 09_14_00-Dynamo.png
    6,233
    01:55 AM
    edit:
    got it working. took some re-configuring but the path from the view to the filter needed adjusting.
    Thanks
    Attached Thumbnails Attached Thumbnails DynamoCropBoundary1.PNG   DynamoCropBoundary2.PNG
  1. Issue with RCP View & Boundary Crop?
    Last Post: June 19th, 2017, 12:04 PM
  2. Crop Region does not show in 3D View with Section box ON
    By sbarrow in forum Architecture and General Revit Questions
    Last Post: May 17th, 2016, 10:24 AM
  3. Crop view
    By ikinks in forum Tutorials, Tips & Tricks
    Last Post: June 23rd, 2014, 02:22 PM
  4. Crop View Region Always Rectangular?
    Last Post: August 1st, 2011, 06:29 PM
