Thread: Visibility parameter and nested family: bug?
    Nantes, France
    1,380
    06:10 PM
    Question Visibility parameter and nested family: bug?
    Hi all,
    I have encounter an issue with a shoring equipment family we work on in my office. I won't share it here (you may understand I can't) but:
    it has 3 levels of nested elements (site category), and the problem is in the last one when we want to apply a visibility parameter to a nested (second level) component; it simply doesn't work. the element is not grayed in the family editor, and is visible when loading in the project.
    we tried it on 2 laptops, same result.
    the only way we found to solve it was to apply a visibilty parameter in the second level nested element, and track it in the final family. this way it works.
    Are we missing something? is this a normal behavior? first time for us BTW.... Thanks.
    4,551
    04:10 PM
    Is it possible to put in a "dummy" family for testing? Strip out all sensitive matters and replace with some random solids.
    3,153
    12:10 PM
    That is the normal behaviour. You did the right thing, tying the object to a visibility parameter in the second level, then tying that parameter to another one in the last level.
    Nantes, France
    1,380
    06:10 PM
    thanks for the answer Alfredo. any idea why it is like that? software limitation?
    3,153
    12:10 PM
    No, it's not a limitation. Imagine this situation: the family that is nested at the second level has 2 extrusions. In the final family, you just want to hide one of the extrusions of the family that is at the second level. Then, having the ability to use individual parameters tells Revit what to hide and what not at the end. But those instructions (such as visibility parameters) have to carried until the host. The final host family is the one that Revit "reads" in the project. Any other instructions not carried out up to the last level are left behind, not "read" at the end. Oops, I hope it makes sense.
  1. Family type parameter for nested families
    By t1shep in forum Architecture - Family Creation
    Last Post: April 3rd, 2018, 12:59 PM
  2. Adding a family parameter via the api
    By KRedman in forum Third party Add-Ins, API and R&D
    Last Post: November 4th, 2013, 01:56 PM
  3. tag nested family
    By precast100 in forum Architecture - Family Creation
    Last Post: July 11th, 2011, 01:02 PM
  4. Nested Family Help
    Last Post: May 19th, 2011, 04:44 PM
  5. Nested Family
    By gdoherty0102 in forum Architecture - Family Creation
    Last Post: May 11th, 2011, 01:27 PM
