Thread: Show Sleeves, Hide Valves & Other Pipe Accessories
    Member koolair's Avatar
    July 31, 2014
    264
    02:57 AM
    Good day everyone, curious how you guys hide main categories, but show subcategories.
    I usually have a workset called SLEEVES so I can do sleeve drawings while hiding all other mechanical stuff.
    But this time I'm minimizing the number of worksets because I have a ton of them - one for each level, one for each link.
    So I created a sleeve family as a subcategory of Pipe Accessories.
    Problem is, I want the subcategory SLEEVES to show, but I don't want valves.
    I also don't want to modify every valve I bring in under it's own subcategory VALVES.
    Would like some help here. Sounds like I'd better stick with a separate SLEEVES workset.
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    397
    01:57 AM
    I would avoid this route and instead filter by another parameter. Consider filtering against the Support Discipline parameter exists (assuming that parameter is available in your sleeve family).
    In general, I use subcategories for objects such as clearance zones within a family whose other geometries I would generally leave on.
    July 31, 2014
    264
    02:57 AM
    Thanks, I never even considered that
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    297
    01:57 AM
    Filters are the way to go for sure. If you're looking to isolate to a specific family you could turn off the others via a filter where the Family Name does not contain "Sleeve". There are other parameters available in pipe accessories to filter by. Find the one that works for you.
    Visibility via worksets is prone to error.
  1. Replies: 1
    Last Post: September 5th, 2016, 03:45 PM
  2. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  3. Show Floor Sleeves, Fade the Rest
    By mdomer in forum Architecture and General Revit Questions
    Last Post: March 18th, 2016, 01:30 PM
  4. Replies: 2
    Last Post: December 24th, 2015, 04:56 PM
  5. Pipe Accessories Schedule
    Last Post: November 26th, 2014, 01:19 PM
