Thread: Displaying 3d pipes the same way as old school cad line types
    May 3, 2017
    03:57 PM
    Hi KEEN REVIT USERS.
    I am wondering if anyone has had any luck displaying continuous text say in "coarse view" only on a 3D pipe that inst a tag? Is this at all possible? I am currently building a hydraulic template in Revit, The only way i have been able to do it so far is: edit the system abbreviation of the pipe family to say "S" then create a pipe tag with a system parameter for system abbreviation in the label. This works well but the only way to tag is either individual tags randomly spaced or tag all which tags ALL pipes, and as you can appreciate with a full drainage system that is a lot of S's
    I have attached a screen shot of what I have created already. Would be awesome if there was anyway to code the actual pipe to display it automatically in coarse view. (or any view for that matter)
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    219
    11:57 PM
    This is not possible in Revit; tags are the only way. This is one of those areas where you will be better off just accepting the "limitations" of Revit and moving on.
    3,071
    12:57 AM
    If you select just the Pipes you want to tag first and then use Tag All Not Tagged, it will only Tag the ones you have selected.
    If you want just one system or Type, perhaps you could set a View Template or a Filter and use Temporarily Apply View Template
    2,661
    10:57 PM
    Quote Originally Posted by evan.dodds View Post
    That's not technically correct... you can make a line-based family with a nested label and trace over all the pipes. It will suck from a BIM perspective, but it can be done.
    December 29, 2014
    Calgary, Canada
    219
    11:57 PM
    It will also suck from a time perspective, and from the fact that the detail component will be on top of everything (not showing what elements are under/ over each other), which I'm pretty sure would be unwanted. The best 'Revit' way would be to use the tag all function, but the OP seemed reticent to that method, which leaves Dave P's method as probably the best option.
  1. How do you create custom Line Types
    By Tiffanydh8 in forum Architecture and General Revit Questions
    Last Post: October 18th, 2017, 02:35 PM
  2. Displaying the Section line on plans
    By danezeq in forum Architecture and General Revit Questions
    Last Post: July 7th, 2016, 12:33 PM
  3. Replies: 8
    Last Post: November 8th, 2013, 08:07 PM
  4. Displaying pipes problem
    By wagurto in forum MEP - General
    Last Post: August 29th, 2013, 09:07 PM
  5. Line types and additive CFM's
    By DMapes in forum MEP - General
    Last Post: May 2nd, 2012, 01:18 PM
