Results 1 to 10 of 14
Thread: Walls Disappear in PDF
    December 11, 2014
    6
    08:57 AM
    Hello all
    we have an issue in our firm we can't find any solution for it, we hope that we find it here
    we draw two separate walls one for brick and one for the internal/external finish (check the screen shot below)
    after we print PDF for any views that contains the above mentioned walls,some of the finish wall disappear in the PDF (check the screen shot below), we have no idea why this happen.
    we find a solution but we can't apply it on a large scale project
    we use show hidden line by element option that help us in this issue as I mentioned we can't use it in a large scale project
    I hope we find the solution here
ID:	30001   Click image for larger version.
ID:	30003   Click image for larger version.
    Attached Images Attached Images
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    907
    06:57 PM
    What pdf writer?
    December 11, 2014
    6
    08:57 AM
    that is happening with adobe PDF ,Nitro PDF and PDF factory
    890
    06:57 PM
    try printing "raster" not vector
    2,796
    06:57 PM
    Adobe pdf writer blows. I use bio-pdf. My AUD0.02
    December 11, 2014
    6
    08:57 AM
    it is working fine with raster but we can't print the drawings with pixels due to the quality control recommendation
    I'll give it a try but I forgot to say something that ,if we export cad this problem occurs also so I think that the problem not with the PDF printer
    890
    06:57 PM
    the problem is therefore not printing in raster ... I'm not sure how you work around that you can't print in raster, because it is often a problem that certain elements don't print using vector processing...
    If you are just printing, try exporting to CAD first then print from CAD to PDF....annoying as hell but I see no other way.
    3,359
    03:57 AM
    There may (long-term, anyway) be hope after all.
    If you haven't read the Autodesk Revit Roadmap, head on over and check it out!
    Buried down a few paragraphs:
    We’re still looking forward to extending the Forge platform by adding PDF printing to the Model Derivative API and by extending the Design Automation API to work with Revit.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,574
    01:57 AM
    I tried that once...and was lost for a week
    January 17, 2013
    01:57 AM
    Possible solution
    I'm guessing that if you haven't figured it out already, it might be too late but... Have you looked at your floors? I've had the same issue and I hid my floor from view and the lines came back.
    Here's the annoying part. I haven't figured out why or what the correct solution is for this. Every go around I've used brings up other issues.
    Hope this helps, sorry it's so late.
    Quote Originally Posted by squiz View Post
    Hello all
  1. Existing walls seem to disappear partially, and new tile on existing wall
    By trevorpan in forum Architecture and General Revit Questions
    Last Post: June 25th, 2016, 05:31 PM
  2. Walls and doors disappear when Model Display is set to Wireframe
    By jverdoes in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 11:52 AM
  3. Dimensions disappear
    By archgirl86 in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2013, 08:18 PM
  4. Portions of UI disappear
    By Steven Thedens in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2012, 10:32 PM
