Thread: In-Place Family Parameter in Multi-Category Schedule?
    234
    04:59 AM
    I cannot get the parameter to show up as an available field. For example, I make a 3D rectangle and label one of the dimensions "L1." It shows up in the object's "Dimensions" property box, but...
    234
    04:59 AM
    Think I got it...
    08:59 AM
    In order to schedule it needs to be a Shared Parameter. Don't know if you can actually do this using an In-Place since I don't use those...
    234
    04:59 AM
    Turns out you can. I got hung up on somehow I thought I needed to create some .txt file or something, but didn't need to.
  1. Adding a family parameter via the api
    By KRedman in forum Third party Add-Ins, API and R&D
    Last Post: November 4th, 2013, 01:56 PM
  2. Multiple value of same material parameter in schedule
    Last Post: September 15th, 2011, 08:35 PM
  3. Groups vs. links -- Multi-family residential
    By tidalwave1 in forum Architecture and General Revit Questions
    Last Post: August 5th, 2011, 12:45 PM
  4. Shared Parameter Category
    Last Post: May 24th, 2011, 11:39 AM
  5. In-Place Family Not Cutting
    By Chadwick17 in forum Architecture - Family Creation
    Last Post: April 14th, 2011, 10:25 PM
