Results 1 to 9 of 9
Thread: Awesome find in Dynamo, by John Pierson (60secondrevit): Crops and section boxes
    10,424
    11:39 PM
    John Pierson found a great correlation between views, and their crop regions, and section boxes, while working in Dynamo the other day.
    He discovered that if you are looking at an Elevation View, its Crop Region element is the Element ID of the view, minus 1.
    So if the view is 55555555, the crop region is 55555554.
    In 3D views, the section box is one below the views element ID, and the crop region is 2 below.
    So if the views element ID is 66666666, the section box is 66666665, and the crop region is 66666664.
    That makes it pretty handy for doing things with section boxes and crop regions, since you can select them directly by element ID.
    Attached Thumbnails Attached Thumbnails 2017-01-10_10-24-22-What Am i missing.png
    4,408
    05:39 AM
    Is this pre or post Tweet?
    (I've been playing as well) - any insight into what were you/John imagining for such a discovery? Thinking maybe tying section box to an element boundary box for isolating elements in view?
    10,424
    11:39 PM
    If you want to get a Bounding Box of a Section Box on a 3D view (for instance), you need to select both the Section Box and the View, to put them in to the BoundingBox.ByElement node you see in the graph. Section Boxes dont have other properties, to really ask "what view am i in?" So without the nifty workaround, you have to do something like this (attached) to both the view, and the section box,(Collect the list of section boxes, and the list of views) then compare the results, and then sift the results out of the Filtered List, which is just a bunch more steps.
    Its just a heck of a lot simpler.
    (EDIT: Its post tweet. I just was excited about his find, so i thought i would share it here after he tweeted about it)
    1,403
    06:39 AM
    Good to know!
    Might be useful to test if it is always consistent or if you can break it. Eg. if you Crop/Uncrop or make custom crop regions will it ever produce a new ID.
    (Its the exceptions to the rule that screw up a good program)
    March 12, 2017
    02:39 PM
    This is great!
    Did you find any correlation between viewport and crop region also for floor plans??
    Andrea
    Member johnp's Avatar
    March 24, 2015
    154
    09:39 PM
    Just saw this thread! Originally I discovered this for obtaining the crop region from interior elevation views to override them to be bolder. Aaron needed it and it seemed to work for 3d as well, so I shared it with the world finally.
    March 24, 2015
    154
    09:39 PM
    Andrea, the floor plan are a bit more tough to figure out. Unlike the other view types, the floor plan alternates between -1 and +3 of the view. Could probably build in logic that checks for this though.
    Member Raff's Avatar
    June 13, 2014
    @EIMHINATWORK
    96
    04:39 AM
    This is like the "text door neighbor" thing https://www.reddit.com/r/textdoor/
    January 23, 2019
    08:39 PM
    I am trying to recreate this but I can only find BoundingBox.ByElements from ClockworkforDynamo..
    can you point me in the right direction for this node? Or may post a file where you get a bounding box from a 3D view and a section box?
  1. Trees and Section Boxes
    By CountryMile in forum Architecture and General Revit Questions
    Last Post: September 15th, 2017, 06:24 AM
  2. Find the surface area of structural beams using Dynamo BIM!
    By Simply Complex in forum Blog Feeds
    Last Post: December 19th, 2016, 07:16 AM
  3. Creating sections that crops to levels?
    By Elliot Mott in forum MEP - General
    Last Post: October 11th, 2016, 07:39 PM
  4. Displacement paths and section boxes
    Last Post: May 3rd, 2013, 03:02 PM
  5. Section Boxes with options
    By goldring in forum Architecture and General Revit Questions
    Last Post: March 16th, 2012, 11:09 AM
