Results 1 to 10 of 17
Thread: Revit links and VG
    November 27, 2012
    633
    01:44 AM
    Revit links and VG
    I have a model with multiple links in, is there anyway of controlling multiple links in 1 go instead of going into each and turning on/off what you need.
    I have maped the grids of one of the links, but then I want to turn off the grids of the other models, is there any quick way of turning them off in one go?
    March 3, 2016
    179
    01:44 AM
    Aren't you using view templates for that?
    11,032
    07:44 PM
    Placeholder Links in your Template, or:
    Create a Vew Template that affects ONLY VG:RVT Links. Set them off (manually) in the one VT. Then apply that VT over the other VT's, and recreate the other VT's from the views.
    But no, for at least one VT, youll have to go in to each link and turn them off.
    November 27, 2012
    633
    01:44 AM
    what do you mean by placeholder links?
    2,780
    10:44 AM
    Quote Originally Posted by nick_h View Post
    I use unique names for grids and levels in each file and turn off the linked ones (uncheck in VG>Filters tab) by using a view filter, Type Name>does not equal.
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    309
    07:44 PM
    Turn off the visibility of the Shared Levels and Grids workset in your host model. Put your grids on a different workset (ex. Shared Levels and Grids_MEP). You may need to open the linked model and put all the grids on the Shared Levels and Grids workset.
    Or
    Don't "include" the V/G:RVT Links category with your master View Templates. Create a separate "Background" VT that only includes the V/G:RVT category with the desired visibility state of the background including the grids. Apply the Background VT to multiple views at once.
    1,405
    01:44 AM
    Quote Originally Posted by kubsix View Post
    Dont do that... put them in the shared levels and grids workset like everyone else should! Thats what it is there for...
    Go to Manage Links, Select a Link, Click Manage Worksets, Close 'Shared Levels and Grids' and they will be globally turned off, for that link, in all your views.
    So long as everyone actually uses the universal Shared Levels and Grids workset this solution works for any link, and in both directions. You could even build it into a template project with dummy links if you wanted.
    Also worth noting that if you use the Filter method and it doesnt work, you need to have a copy of the linked family you want to filter in your own model too. So copy paste it once.
    November 27, 2012
    633
    01:44 AM
    cheers ive gone for this method for time being..
    will try the shared levels & grids workset, once ive set it up as a central model.
    March 31, 2011
    309
    07:44 PM
    Yes...or that...and thank you very much for the gentle nudge/reminder of that feature.
    11,032
    07:44 PM
    Search for it, and youll find a long explanation.
    For what its worth, i wouldnt rely on Worksets (yours OR other peoples) AT ALL for controlling the grid visibility. But your mileage may vary. Thats also discussed in all the other threads.
  1. Help - Revit worksets management in links of links
    By trimtab in forum Architecture and General Revit Questions
    Last Post: October 12th, 2016, 10:38 AM
  2. Revit LINKS
    Last Post: January 12th, 2015, 03:20 PM
  3. Revit Links
    By Shields08 in forum Worksharing, Revit Server & C4R
    Last Post: February 22nd, 2013, 10:55 PM
  4. Revit links
    By edsoncachel in forum Architecture and General Revit Questions
    Last Post: January 23rd, 2013, 04:54 PM
  5. Revit Links
    By Thapelo Letsoalo in forum Architecture and General Revit Questions
    Last Post: June 13th, 2012, 12:40 PM
