Thread: Mechanical TAG: Revit is changing My formula to another formula
    October 29, 2015
    6
    09:20 AM
    I've created a Mech Tag for tagging Radiators, i've added Liters per hour to the formula.
    My formula
    (Power x (0,86 / ΔT), Example: 10000w x 0,86 / 15 = 573,3 Liters per hour.
    After clicking OK in the "Calculated Value" window,
    Revit changes the formula to (Power x (0,9 m2/kN / ΔT) Example: 10000 x 0,9 / 15 = 600 Liters per hour.
    The difference is to big, especially on larger projects.
    Does anyone have an idea why Revit is changing my formula?
    I'm located in Sweden, we don't use (m2/kN), could this be the problem?
    October 29, 2015
    6
    09:20 AM
    Solved it with another formula.
    It seems that the decimals is creating the problem.
    The new formula, if anyone is interested is: "Power * ((86 / 100) / ΔT)"
    Also works with MagiCAD "MC Piping Power * ((86 / 100) / ΔT)"
    6,229
    05:20 AM
    Thanks for posting your solution
  1. Revit Formula Query
    By Beaucoupnice in forum Architecture - Family Creation
    Last Post: October 14th, 2015, 11:57 AM
  2. Revit Family Formula Help
    By knkagaki in forum MEP - Family Creation
    Last Post: June 23rd, 2015, 03:25 PM
  3. Revit Formula Syntax
    By Revitista in forum Architecture - Family Creation
    Last Post: April 18th, 2014, 02:09 AM
  4. Changing Materials with a Formula
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: January 4th, 2013, 03:07 PM
  5. Schedule formula (is there a formula expert in the house?)
    Last Post: September 9th, 2011, 09:50 PM
