Thread: Adjusting Angles for Pipe Fittings
    Junior Member RenChan's Avatar
    March 30, 2016
    25
    02:43 AM
    My company wants to use longer radius reducing pipe fittings based on a particular manufacturer. We have the correct fittings built, however it does not have the ability to adjust its angle from 90░ to 45░ or any other angle. I have an older fitting that does adjust it's angle, but the sweep is too short. Would it be best to alter the built family that has the correct long sweep or the old family that has the correct angle behavior but the wrong sweep? Or would I have to just create a new family from scratch?
    With either option I could use some help if anyone has found a good guide or knows some good tricks to getting this to work.
    Thank you,
    -RenChan
    September 16, 2015
    Darwin, Australia
    169
    08:13 PM
    I downloaded both families and I could alter the angle of both of them, however the geometry for one connector is in the wrong location on the long bend. I haven't played with pipe bends yet (been putting it off), so I can't offer any wizardry, but I'm sure someone else here can.
    I've always found it easier to build a new family from the ground up with the knowledge I gain from doing it the wrong way. Rather than trying to modify something that may have been built wrong from the start. The more complicated the family (pipe fittings can be) the more I'm inclined to start from scratch, but it's ultimately up to you.
    I think you may be able to edit your way out of this one; it just seems to be the connector location. I'd give it a crack myself but I am running 2017.
    March 30, 2016
    25
    02:43 AM
    After taking a weekend off I came back with a fresh start and somehow managed to get this to work. It was a matter of a part needing to be deleted, the connector reassigned, and then setting the connection to the correct angle. Thankfully this trick also worked for the long sweep reducing tee I was trying to complete.
    Thank you for replying to my thread and for the tip.
    -RenChan
    September 16, 2015
    Darwin, Australia
    169
    08:13 PM
    Glad to hear you got it sorted out. Sometimes stepping away from the problem and returning later is the best thing to do.
  1. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  2. Pipe fittings not shading
    Last Post: August 17th, 2015, 09:37 AM
  3. Pipe fittings not updating
    By JPREng in forum MEP - General
    Last Post: July 9th, 2015, 03:36 PM
  4. Steel pipe and fittings
    By tzframpton in forum MEP - Family Creation
    Last Post: July 16th, 2014, 12:31 PM
  5. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
