Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Documenting a family element
    Junior Member D_Incognito's Avatar
    August 31, 2016
    Lake Wylie, SC, USA
    14
    04:17 PM
    I created a very detailed parametric family of a front door unit. I loaded it into my project and it works great and looks great. I would like to show just the model of the door on a sheet for my mill-work shop. I need the sheet to have the typical front, vertical section and horizontal section, as well as a dimensions, detail views and material list. I could not sea a way of doing this in the family editor. I would like the sheet to be included in the project sheet set with other mill-work items like these trusses after my interior elevations. I have done this for years in Auto-Cad and Inventor. How is this done in Revit?
    After hours of searching I had to post this question.Click image for larger version.
Name:	Percy Renovation Roof Framing.jpg
ID:	28232Click image for larger version.
Name:	Front Entry.jpg
ID:	28233 Click image for larger version.
Name:	7 Two PostTransom w High Arch w Stone.jpg
    Member Barth's Avatar
    December 2, 2013
    301
    01:17 PM
    you wouldn't do this in the family; you'd do it in the project by setting up the views you want and placing your dimensions in those views. Then put those views on a sheet with your schedule. Or...am I totally misunderstanding you? Your work suggests that you obviously have a good grasp of Revit, so I'm probably not reading your question right.
    BTW: Nice Work.
    1,355
    10:17 PM
    You can make an assembly of it as well, this lets you create the views you need with just a few clicks and add them to a sheet. Just select the door and click the make assembly icon (next to the create group icon). Once you have the assembly (it will end up all the way to the bottom of your family browser) you can right click it and choose what views you want to make.
    August 31, 2016
    Lake Wylie, SC, USA
    14
    04:17 PM
    Here is a sheet I produced from a model in Inventor. This is what I'm trying to do with Revit.
Name:	Millwork Drawing.jpg
    August 31, 2016
    Lake Wylie, SC, USA
    14
    04:17 PM
    That Icon is gray.
    August 31, 2016
    Lake Wylie, SC, USA
    14
    04:17 PM
    Robin,
    That option is gray for some reason. The project has several phases and many options for this front entry design. Maybe Something is with these setting is inhibiting the make assembly icon active.
    1,355
    10:17 PM
    mmm, not sure why that is, would say it is the options. You can always just make elevation en section views for that window and add them to a sheet.
    Anway, the window sheet I make:
Name:	window sheet.jpg
    The Windows schedule you see on my sheet is not the one from the assembly, that just count the assembly and still gives a count of 1 when you have multiple of the same window.
    1,355
    10:17 PM
    Just tested and indeed the assembly function is grey when you have options for that window.
    Trying to think why and I'm guessing Revit wants you to choose an option before documenting your model. To bad that does not work in real life sometimes.
    August 31, 2016
    Lake Wylie, SC, USA
    14
    04:17 PM
    That looks like what I am attempting to do. What is the process?
    1,355
    10:17 PM
    It does involve assemblies for this example, but I guess you can just make a few elevations and sections. A short explanation of the process:
    01. Create an assembly from the windows
    02. In your project browser (at the bottom) right click the assembly and choose 'create assembly Views'
    03. Choose which View you want to make (I have Elevation Front, Detail Section B, Plan Detail and 3D Ortho)
    04. I would not choose sheet and schedule as I think making them the 'normal' way is better
    05. Clean up your views and mnake them look the way you want with dimensions, text, etc.
    06. Creat a sheet the 'normal' way
    07. Drag the Assembly views onto that sheet
    08. Make a Window Schedule and filter it so you just have that 1 windows type on it
    09. Drag that to the sheet too
    10. DONE !
    You could make some details too if you like and add them to your sheet.
    Without the assemblies the process is about the same, just make the needed views.
    Last option is to create a Legend but I do not like that option.
    Really too bad there is no easy way for a 1 click windows /door sheet, yet.
  1. Documenting Grouped Units
    Last Post: February 11th, 2016, 11:28 PM
    Last Post: November 3rd, 2015, 11:15 AM
  3. Documenting a Revit Library
    Last Post: December 21st, 2012, 06:15 PM
  4. Documenting the Revit Template
    By kpcarch in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2012, 10:42 PM
  5. Inside the System: Documenting Multi-Section Panels
    Last Post: September 12th, 2011, 01:20 PM
