Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: CAD file Imported or Linked?? not loaded in ML but shows up anyway?
    Member wwdreamb's Avatar
    May 19, 2016
    Honolulu, Hawaii
    120
    07:20 AM
    I am working in a model that has a few CAD files linked or imported into it. When I go to plan or 3D view where I can see them, I am unable to highlight, grab, select or move the CAD files. In manage links they both show up but are unloaded. If I remove the links they disappear from the model. We currently do not have these files in our system.
    What is going on? Is the file linked? If so, why is it showing up while the status is "not found" in Manage Links?
    Are the drawings imported but for some reason show up in Manage Links?
    Member Barth's Avatar
    December 2, 2013
    301
    07:20 AM
    Lower right corner: "Select Links" : Toggle it.
    2,642
    12:20 AM
    Also cad files can be pinned when brought in. Check 'select pinned' setting
    June 14, 2011
    CT, USA
    592
    10:20 AM
    [QUOTE=wwdreamb;174678]We currently do not have these files in our system. QUOTE]
    Revit does not need the .dwg file to hold on to the geometry. It will even export said geometry.
    Member HansLammerts's Avatar
    April 22, 2011
    475
    02:20 PM
    Like rob says. linking is really not 'link' .. It's more like 'import with a leech'.. It will always import ..however it you choose 'Import' it doesn't have the leech in the first place. Hope that it makes more sense to you
    10,410
    09:20 AM
    Importing and linking are nowhere near the same thing. Importing is way worse. It brings in a ton of other crap from the cad file, that doesn't (and shouldnt) need to be in revit.
    April 22, 2011
    475
    02:20 PM
    Yes. All familiar Aaron. We don't need to discuss dwg any further. I think now with the .sat capability in 2017 loose all the crap that Revit imported. However, too bad we loose the leech as well. The workaround for that will be easy, don't you think?
    10,410
    09:20 AM
    I dont agree at all, because SAT isnt going to replace DWG for a lot of people. Folks bring in full drawings in DWG. SAT is typically used when they want to pull in geometry from other platforms (which i dont do, i just model them in Revit).
    April 22, 2011
    475
    02:20 PM
    That is your view. I've just got a other angle at this. No problem Aaron..
    I think (working civil ALSO with AutoCAD 2d and 3d intensively..) that (sub)models can be exported from AutoCAD better as .sat for better use than dwg in Revit. It's open & clean! And like you said. AutoCAD is a different platform! (hence the logic). When designing bridges and tunnels, .. Steel, ships or whatever... Solids have the the preference. (except for terrains and roads etc) A good 3d designer in AutoCAD keeps 2d and 3d in different files if you ask me.
    However, with .sat you are ganranteed it will NOT bring the garbage in that people experience with dwg (thanks Autodesk !!!!). [EDIT .. THE POINT IS HERE!]
    Time will tell, we will see Aaron. ( getting a little of topic by Aaron.. Sorry for that)
    10,410
    09:20 AM
    You always assume the moment people mention DWG that its 3DDWG, because thats your workflow.
    So you have a Flat 2D Site Plan, that you export to SAT, and it comes in with all of the civil engineers annotations and symbology from their drawings? Sweet, post one up. Ill link it in and if it truly is better, ill say i was wrong.
  1. Where is that imported CAD file?
    By SarahF in forum Architecture and General Revit Questions
    Last Post: May 30th, 2017, 01:24 AM
  2. linked file to another linked file view and control problems
    By shotgun_banjo in forum Architecture and General Revit Questions
    Last Post: May 4th, 2016, 12:47 AM
    Last Post: October 9th, 2015, 01:15 AM
    Last Post: July 9th, 2014, 12:15 AM
  5. Linked model shows regardless of workset
    By edmund in forum Architecture and General Revit Questions
    Last Post: March 7th, 2013, 10:02 AM
