Thread: Mechanical & Electrical Tags
    August 29, 2014
    12:59 PM
    I have created our company standard Mechanical Tags.
    I have created our library of mechanical equipment, which contain a yes/no parameter to define whether the item of equipment requires an electrical supply.
    I have created a filter based on this parameter which controls the visibility of the mechanical equipment family,
    but I am struggling to display the mechanical equipment tag in an electrical view (I do know that this obviously wont appear in an electrical view) but is there a work around.
    I am trying to populate a power view with mechanical equipment and their references which require a power supply.
    September 18, 2016
    12:59 PM
    Quote Originally Posted by stuart king View Post
    Hi.
    I think what you need to do is to create these parameters as shared parameters so you can make them visible in tags. Try that and see how it works for you
  1. Room tags in Mechanical View
    By Dogma in forum MEP - General
    Last Post: June 13th, 2014, 01:46 PM
    Last Post: May 11th, 2012, 05:57 PM
  3. Default Position of Door Tags (or any tags for that matter):
    Last Post: December 23rd, 2011, 08:45 PM
  4. Mechanical or Electrical
    By dzatto in forum MEP - General
    Last Post: May 26th, 2011, 03:03 AM
