Results 1 to 6 of 6
Thread: Rename View by Matching Elevation Tag with Room Number
    July 19, 2011
    New York City, NY
    55
    02:08 AM
    All,
    I have been asked recently by a client on how to rename all elevation views (title on sheet parameter to be exact) that belong to rooms that respective elevation tags are located on.
    I first looked at the API solution by Jeremy here:
    The Building Coder: Rename View by Matching Elevation Tag with Room
    And thought maybe Dynamo could do the same thing and turned out it did.
    This Dynamo nodes can potentially save you alot of hours renaming views...
    2016-08-23_1538 - nnguyenparallel's library
    PM me if you want the nodes...
    Ngoc
    May 26, 2017
    07:08 AM
    Amazing work! May I trouble you for the code?
    February 7, 2018
    07:08 AM
    Quote Originally Posted by ngoc nguyen View Post
    All,
    Ngoc
    Amazing,Might I be chanced to get the code from you Sir?
    Member johnp's Avatar
    March 24, 2015
    175
    12:08 AM
    This is a bit more reachable these days with some custom packages,
    6,329
    01:08 AM
    Quote Originally Posted by johnp View Post
    is it possible to pull plan orientation through Dynamo also, so the elevation includes it?
    i.e. Elevation-Bathroom 123-North
    March 24, 2015
    175
    12:08 AM
    Quote Originally Posted by cellophane View Post
    Probably
  1. Replies: 20
    Last Post: November 23rd, 2015, 09:31 AM
  2. Rename a boat load of sheet number?
    By Dave Jones in forum Architecture and General Revit Questions
    Last Post: November 7th, 2013, 03:20 AM
    Last Post: March 21st, 2013, 11:15 AM
  4. Room Number & Space Number
    By LKeyser in forum MEP - General
    Last Post: July 3rd, 2012, 03:48 PM
  5. Elevation Tags not updating View Number
    By ptranberg in forum Architecture and General Revit Questions
    Last Post: May 11th, 2011, 08:14 AM
