Thread: Diffuser Visibility - Strange
    July 2, 2014
    03:26 AM
    So I placed some diffusers in a ceiling plan in a new project. They are hosted to the linked architectural ceiling grid. No big deal, done it 100 times. They were visible on the HVAC floor plan when I originally placed them. Now they aren't visible on the floor plan at all, but still visible on the ceiling plan. When I draw a new diffuser (exact same family), it's visible on the floor plan. I can't figure out how to make the original diffusers I drew show on the floor plan. Any ideas? Worksets are correct, all visibility is on. Diffusers are still hosted to the ceiling plan. I'm stumped.
    Thanks for any help!
    Brian
    July 2, 2014
    03:26 AM
    Nevermind. Goober hid all the ceiling diffusers.
    March 2, 2016
    13
    02:26 PM
    If the elevation of these Diffusers higher than Cut plane value of View range and the discipline of this floor plan is Architectural or Structural they will do not display (If the elevation of them lower than Cut plane they still display), then you should change Discipline to one of MEP Disciplines. And you should check the view depth value of floor plan, with floor plan (not ceiling plan) it must lower than Cut plane. This is my ideal
  1. Diffuser family does not actually attach to the Ceiling Grid?
    By amoroso in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2015, 03:49 PM
  2. Revit Sample family louver's strange visibility behavior-Help
    By mkashifafzal in forum Architecture and General Revit Questions
    Last Post: October 28th, 2013, 12:17 PM
  3. Loading of Diffuser family
    By zacoolm in forum MEP - General
    Last Post: April 22nd, 2013, 07:54 PM
  4. Add flow arrow to diffuser
    Last Post: March 21st, 2013, 09:59 PM
  5. Titus diffuser families
    Last Post: February 20th, 2012, 04:24 PM
