Thread: Insert linked revit file
    December 31, 2010
    Singapore
    195
    07:46 AM
    Is it possible to insert a linked revit file in a similar manner to inserting a xref in CAD?
    Kingdom of Denmark
    4,276
    01:46 AM
    Sure thing - Go to the "Insert" tab, and pick "Link Revit"
    The below is straight from the help file...
    1. Open an existing project or start a new project. You will link another project into this project.
    2. Click Insert tabLink panel (Link Revit).
    3. In the Import/Link RVT dialog, select the Revit model to link.
    4. For Positioning, specify the desired option. In most cases, you should select Auto - Origin to Origin. If the current project uses shared coordinates, select Auto - By Shared Coordinates. See Shared Positioning. See Import and Link Options for CAD Formats and Revit Models.
    5. Click Open.
    If you cannot see the linked project in the drawing area, do the following:
    1. In the view properties, for Discipline, select Coordination. This setting ensures that the view displays elements for all disciplines (architectural, structural, mechanical, and electrical).
    2. (Optional) To display the linked project in halftone, for Visibility/Graphics Overrides, click Edit. On the Revit Links tab, for the linked project, select Halftone, and click OK. You can select the linked model in a view and drag, copy, paste, move, and rotate it. You can also monitor grids, levels, and other essential elements in the linked project. See Multi-Discipline Coordination.
    Alex Cunningham's Avatar
    Northern California
    3,576
    04:46 PM
    1.In the view properties, for Discipline, select Coordination. This setting ensures that the view displays elements for all disciplines (architectural, structural, mechanical, and electrical).
    I am glad you copied this part. I get many complaints that people cant see elements in there model or linked file. It's an easy thing to miss.
  1. Insert from File - Drafting Views
    By doabledave in forum Architecture and General Revit Questions
    Last Post: May 12th, 2011, 12:52 PM
  2. Insert a Linked Revit File
    Last Post: May 1st, 2011, 07:08 PM
  3. Linked Revit files OFF by default
    Last Post: March 17th, 2011, 02:31 PM
  4. Keynoting Linked File Work arounds........
    By drafterjohn in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 08:42 PM
  5. Linked Models - "File Not Saved"
    By Dandharma in forum Architecture and General Revit Questions
    Last Post: December 12th, 2010, 04:16 AM
