Thread: Door Schedule in MEP?
    Member Gabriel Black's Avatar
    April 6, 2011
    Belgium
    203
    11:26 PM
    I need to produce a door schedule that won't confuse my engineers, in other words it must have the same columns and information that the AutoCAD one used to have.
    What I need to know is:
    Is there a built-in parameter in the doors family for "swings open left to right" or "right to left" and what is the parameter name?
    Is there a built-in parameter in the doors family for which room it leads into and what is the parameter name?
    I have a work-around in mind, but then I can't use the cute flip arrows for changing the swing of the door as far as I know. I'd have to make the doors static. Openinig either "Swings/slides open left to right" and Swings/slides open right to left" and include these as parameters in the family to be able to schedule them.
    The room name I'd have to also make as a 'schedulable' parameter too if no such function exists.
    Ciao for now.
    Kingdom of Denmark
    4,245
    10:26 PM
    Quote Originally Posted by Gabriel Black View Post
    ...Is there a built-in parameter in the doors family for "swings open left to right" or "right to left" and what is the parameter name?...
    No, or at least it┤s not available without utilizing the API - But Feio made a cool add-in which does just that:
    http://revitforum.org/showthread.php/764-New-API-utility
    ...Is there a built-in parameter in the doors family for which room it leads into and what is the parameter name?
    It┤s not a visible parameter in the family, but when you create a schedule, and under "Select available fields from" select "To Room" or "From Room" you┤ll get a lot of parameters to include in the schedule.
    You might wanna read this thread first though:
    http://revitforum.org/showthread.php...n-door-flipped
    April 6, 2011
    Belgium
    203
    11:26 PM
    Thanks so much! Oddly enough, I came accross that thread before I posted this question and read through it.
    I'll try the "To Room" & "From Room" adding in thing - thank you!
    I'll also have a look at that add-in...if IT will allow it.
    Thank you again for the advise!
  1. Curtain Wall Door - Level in Schedule
    Last Post: June 18th, 2019, 04:42 AM
  2. Door properties "From Room: Number" does not change when door flipped
    Last Post: September 19th, 2012, 07:48 PM
  3. Schedule: Count only what's shown in schedule...
    Last Post: July 17th, 2011, 03:57 PM
  4. Transitioning from AutoCAD MEP to Revit MEP
    By tzframpton in forum MEP - General
    Last Post: May 16th, 2011, 12:41 PM
  5. Door Schedule hiding Rows
    Last Post: April 6th, 2011, 04:27 PM
