Thread: help to display pipe with with only single line
    February 18, 2016
    6
    05:56 AM
    Do everybody know how to edit the fitting pipe in medium display. I do not want to show to 2 horizon line in the head and tail of the fitting. I 've found many ways to solve, but it sounds disappointed
    Please see the attached file for clear information.
    January 17, 2011
    2,057
    12:56 AM
    Open the fitting, and select the "ticks" and set them to not visible and reload. You could delete them, but I would not advise that.
    You can also get rid of the radius too and just join the two segment lines together. I personally have done this.
    February 18, 2016
    6
    05:56 AM
    Ok, I did it, thanks you very much, i truggled with that for a long time. hic
  1. Single line pipework layout
    Last Post: October 16th, 2015, 03:23 PM
  2. Why when i draw pipe it shows single line ??!
    By ahmed_hassan in forum MEP - General
    Last Post: August 15th, 2012, 04:10 PM
  3. single line display issue
    By RStiles in forum MEP - General
    Last Post: July 9th, 2012, 10:54 PM
  4. display all door & window tags on a single split level plan
    By msarkor in forum Architecture and General Revit Questions
    Last Post: March 4th, 2012, 10:56 PM
  5. representation of beams is just single line !!!!!?
    Last Post: January 1st, 2012, 09:10 PM
