Results 1 to 6 of 6
Thread: Revit text generator
    March 11, 2016
    9
    09:38 PM
    Question Revit text generator
    Does anybody have any good links on how to use the Revit extension tool text generator? I get errors when I link word files, so that won't work. Cutting and pasting the text into the box doesn't seem any better than just doing the same directly into a text command word box. The autodesk help barely has any info on it.
    July 4, 2013
    179
    08:38 PM
    I link word files no problem. Post an example error.
    March 11, 2016
    9
    09:38 PM
    error
    REX:
    Engine version: 2016; Version name: ; Culture info: en-US
    PLATFORM:
    Win32NT Microsoft Windows NT 6.2.9200.0
    SOURCE:
    AREX
    MESSAGE: (3/23/2016 1:57:39 PM)
    Unhandled exception.
    Assembly name: DRevitTextGenerator: The process cannot access the file 'C:\Users\christoph\AppData\Local\Temp\DTextGen\do c.txt' because it is being used by another process.; StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
    at System.Windows.Forms.RichTextBox.LoadFile(String path, RichTextBoxStreamType fileType)
    at REX.DRevitTextGenerator.Resources.Dialogs.ControlM ain.button_path_Click(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    DEPENDENCY: Autodesk.REX.Framework, Version=2015.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2015.0.0.3253) | REX.Controls, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Controls.WPF, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Controls.Forms, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Mathematics, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Preferences, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.System, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511) | REX.Service, Version=2016.0.0.3511, Culture=neutral, PublicKeyToken=null (file version: 2016.0.0.3511)
    LAST ENTRIES: 4 / 17
    16: (3/23/2016 1:36:39 PM)
    AREX.Engine - Unhandled exception.
    15: (3/23/2016 1:33:09 PM)
    14: (3/23/2016 11:27:58 AM)
    13: (3/23/2016 11:27:51 AM)
Name:	Screenshot 2016-03-23 13.38.19.png
    3,194
    09:38 PM
    Second line under MESSAGE:
    Sounds like you have the file open in Word & evidently Revit doesn't like that.
    Try closing Word before you run the Add-In
    March 6, 2011
    Aurora, Colorado, United States
    4
    08:38 PM
    Check out this Revit add-in from the Autodesk App Store.
    https://apps.autodesk.com/ACD/en/Det...windows64%3aen
    Rich Text Editor
    Centek Software, LLC
    Todd Behning
    Corporate BIM Manager
    March 11, 2016
    9
    09:38 PM
    No the file was close out of word many of the times I tried. Not open in any applications I know of. Perhaps when I tried to bring in the text and copy the error it was a time when the file was open elsewhere. Since I asked this question and we have new licenses and a new server, and I no longer have the extension :/ Thanks for trying to help me.
    Last Post: October 17th, 2013, 12:15 AM
  2. Revit OpEd: Grids Generator Extension
    By Revit OpEd in forum Blog Feeds
    Last Post: May 8th, 2013, 04:15 PM
    Last Post: December 1st, 2011, 12:18 PM
  4. Alive in the Lab: Structure Generator for Revit Now Available
    By Alive in the Lab in forum Blog Feeds
    Last Post: November 23rd, 2011, 03:45 PM
  5. Revit based pattern generator add-on?
    By Gordon Price in forum Architecture and General Revit Questions
    Last Post: February 8th, 2011, 10:07 PM
