Thread: Move fan electrical connector
    Member gru3d's Avatar
    March 2, 2016
    57
    08:54 AM
    I need to move the electrical connector of this fan, which is too far away from the wall. Can somebody point me out how to move the electrical connector?
    Link to CaptiveAire CEPRSM RFA archive
    https://www.captiveaire.com/Revit/Ca...d_wShutter.zip
    Additional data (not required): DWG with precise dimensioning of physical parts (web and direct link):
    https://www.captiveaire.com/CATALOGC...0&Model=CEPRSM
    https://www.captiveaire.com/images/C...ithShutter.dwg
    1,402
    10:54 AM
    Connectors are always placed on a face and automatically center themselves in the middle point of the chosen face.
    If you select the connector you might be able to select a different host face. Otherwise delete it and place a new one where you want it.
    If necessary create a small extrusion to put it on, which you can move to the right place.
    2,658
    01:54 AM
    You can also use Split Face to create a surface for the connector to avoid the extrusion.
  1. Tagging Electrical Connector Description Property
    By danbush in forum Architecture - Family Creation
    Last Post: March 15th, 2016, 10:57 AM
  2. Arrays: Move to 2nd vs Move to last
    By BLothian in forum Architecture and General Revit Questions
    Last Post: May 12th, 2014, 03:31 PM
  3. Link a connector to more than one
    By tech_cjs in forum MEP - Family Creation
    Last Post: May 19th, 2012, 04:29 PM
  4. Electrical Equipment vs. Electrical Fixture
    By jsnyder in forum MEP - Family Creation
    Last Post: August 29th, 2011, 09:24 PM
