Thread: 4 Visibility Options with Unique Serial Numbers Appearing in a Schedule
    November 15, 2014
    02:42 PM
    Hi All,
    Can anyone please help me with this?
    - I need to have 4 visibility options
    - Each of the 4 options have varying serial numbers
    - When an option is selected, the rest should automatically be unselected
    - When an option is selected, its serial number should be displayable in a project schedule
    Thanks in advance.
    Andre
    2,661
    11:42 PM
    You'll need a new parameter (most likely an Integer) where you ask the user to select 1-4 (or whatever) and change visibility based on the result. The serial number would be an if/then based on the integer as well.
    Wellington, New Zealand
    672
    07:42 PM
    Or - just setup the types correctly and give the types a valid name so your users don't need to select an option, they just select the correct family type
    September 16, 2015
    Darwin, Australia
    169
    05:12 PM
    Yep, I'd just go with family types. I've pulled out enough hair recently trying to set up multiple Yes/No visibility parameters to work around each other.
    November 15, 2014
    02:42 PM
    Thank you guys for the replies. I tried creating the options using 4 integers and loaded them in a project and created different family types and they all work great. Thank you.
  1. Room Schedule - Project Parameter with Multiple Input Options?
    By sbopp in forum Architecture and General Revit Questions
    Last Post: December 18th, 2015, 04:46 PM
  2. Room/Space Names and numbers within Mechanical schedule
    By mcole254 in forum MEP - General
    Last Post: September 23rd, 2014, 01:19 PM
  3. schedule links and design options
    Last Post: November 14th, 2013, 08:18 PM
  4. schedule design options
    Last Post: October 29th, 2013, 01:28 AM
