Thread: Length Parameter to Text
    September 16, 2015
    Darwin, Australia
    169
    07:43 PM
    Hi all,
    Simple question: Can two length parameters be combined into a text parameter?
    Example: Face Size (Text Param) = "Width (Length Param)" x "Depth (Length Param)"
    I've had a couple of attempts but keep returning inconsistent units. It doesn't seem reasonably possible, but I thought I'd ask the community. I could use Boolean expression, but I'd spend a year (at least) writing it.
    Any ideas?
    6,229
    05:13 AM
    You can do it with some third party apps and probably Dynamo but I don't believe there is a way to do that OOTB.
    KiwiCodes Bonus Tools has a tool to copy parameters - to get the result you want you would need a parameter that does the math and your text parameter.
    AreaCalc = WxD
    AreaText = AreaCalc copied through API
    The only problem with this approach is that it isn't up to date unless you run the tool again.
    September 16, 2015
    Darwin, Australia
    169
    07:43 PM
    Cheers for that, I'll check out those tools and see how I go.
    November 12, 2015
    25
    05:13 AM
    You should be able to get by that error by cancelling the units yourself. For instance in your example you have ft*ft in your units and you want to have unitless text. Try =Length/1ft* Width/1ft.
    Sent from my Nexus 6 using Tapatalk
  1. General Annotation Family with Length Parameter using Grip?
    Last Post: October 27th, 2015, 01:27 PM
  2. Accessing the cut length parameter for tagging.
    By BoBMudd2 in forum Structure - General Questions
    Last Post: July 8th, 2015, 12:55 AM
  3. Duct Size vs Length parameter
    Last Post: November 26th, 2014, 05:58 PM
  4. Use Cut Length parameter in a formula???
    By JasonZischke in forum Structure - Family Creation
    Last Post: August 5th, 2013, 11:15 PM
  5. Text Length in Tags
    Last Post: January 30th, 2012, 04:08 PM
