Thread: Can't Reassign Workset
    August 3, 2015
    115
    01:41 AM
    I make a selection of elements, go to properties and the workset dropdown is grayed out? What gives?
    Pipe, pipe fittings, and plumbing fixtures. What's more confusing is the plumbing fixtures I was able to change the workset on.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    12:41 AM
    Sometimes you have to filter categories to mass change worksets...
    4,443
    09:41 AM
    Are any of these elements in your selection:
    Checked out
    Pinned
    In groups
    August 3, 2015
    115
    01:41 AM
    Snowy, none of the above. I did find a solution.
    I made 4 schedules to select all the elements pipe, fittings, fixtures, acc. I selected all in the schedule and showed in model, then saved as a selection set. I isolated elements, off clicked and re-selected. Then I was able to change the workset.
    4,443
    09:41 AM
    Sounds to me like you had something in your original selection (made in a view rather than a schedule that time I presume) that isn't workset-assignable (a tag for example).
    Glad you got it sorted.
    August 3, 2015
    115
    01:41 AM
    I thought that was the case, however, I selected a single element and tried to change the workset. I'm using 2016.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    465
    01:41 AM
    dpStuff has a fairly inexpensive plugin for Revit called Workset Explorer that does just this.
    dp Stuff - Custom Revit API Addins | Design Technology | Parametric Modeling
    $10 and you get all their tools. I use it all the time!
    February 29, 2012
    66
    03:41 AM
    For what it's worth, I've found that groups are often the culprit for this type of problem. If one fitting within the selection is part of a group (or array group), then the workset property will be read-only for the entire selection set.
  1. Workset tutorial
    Last Post: June 9th, 2014, 08:32 PM
  2. workset
    By sepideh in forum Structure - General Questions
    Last Post: June 6th, 2013, 06:36 AM
  3. To Workset or To Not Workset?
    Last Post: September 9th, 2011, 08:06 PM
  4. Cannot turn off a workset
    By mfiglarz in forum MEP - General
    Last Post: January 19th, 2011, 12:43 PM
