Thread: lighting fixtures reducing performance?
    December 31, 2010
    Singapore
    195
    11:59 PM
    Hi peps. I've got an issue that's reducing the speed of my file. I'm doing a landscaping lighting plan using lighting fixtures to give an impression of lighting spreads etc. I'm now getting a problem theat every time I try to edit anything I get a processing message (bottom left hand corner) telling me that its regeneration the 3D views, these view are what I'm using to output schematic lighting plans. Even if these views are not open revit still needs to update them. These lighting plans do not have a many lights in them, or is 20 alot? Is so then thats the problem. Is there a way of stopping revit from updating or regenerating these views in the background?
    thx!
    2,652
    08:59 AM
    Revit doesn't/shouldn't regenerate a view that's not open. Are you sure the view is closed?
    December 31, 2010
    Singapore
    195
    11:59 PM
    Absolutely certain, the light fixtures are also on their own workset and are switched off in all 3d view while I am positioning lights in plan. I even deleted the views that were being regenerated but revit then switched to another 3d view to regenerate, its like it needs to keep track of the illumination or something. I'll just keeping trying to find solutions for the issue.
    December 31, 2010
    Singapore
    195
    11:59 PM
    To sort of answered my own question. I've discovered that if I place a bunch on lights into the model and not open any of 3d views my machine will not need to regen any 'background' 3d view. But if I open a 3D view and even if I close that view, revit will still need to update/regen that view, if I delete the offending view it will simply jump to the next one. My guess is that revit need to keep an illuminance map somewhere in the cache, but this slows down performance terribly. Sounds wacky but its a happening.
    May 14, 2012
    392
    09:59 AM
    So it sounds like if you close out of the file and re-enter, the performance improves, right? If so, what happens if you make sure all the 3D views are closed and you SWC, relinquishing everything?
    December 31, 2010
    Singapore
    195
    11:59 PM
    Saving out and re-opening & SWC does work....... for a while but then something triggers the regen process again. I'm pretty sure its someone else on the team opening a 3d view and SWC. The short of it - don't have too many light fixtures in the project, if you need them, then put them in a separate file - lighting study. The hardware just can't keep up.
    thx
    December 31, 2010
    Singapore
    195
    11:59 PM
    The problem was VRAY, I uninstalled and performance returned to normal. 'Beta' be careful.
    December 20, 2010
    1,079
    11:59 AM
    I can concur, VRAY just starts sucking memory. I had to uninstall it too.
  1. Replies: 3
    Last Post: April 7th, 2016, 07:24 AM
  2. lighting fixtures (ceiling) rendered on pc but fails in cloud rendering
    By mdingemanse in forum Rendering and Gallery
    Last Post: June 26th, 2015, 08:20 AM
  3. Lighting fixtures Category, nesting, hosting
    By anthonyB in forum Architecture - Family Creation
    Last Post: August 21st, 2014, 10:20 PM
  4. interior rendering without using lighting fixtures
    By ehsanshp in forum Architecture and General Revit Questions
    Last Post: April 29th, 2013, 03:26 PM
