Results 1 to 10 of 10
Thread: Glass door with side lite
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    04:04 AM
    I created a glass door family with a side lite. I have all the parameters so I can change the door width and the overall width (which would change the side lite width accordingly). It's working pretty well. Here's my question: how can I schedule the door separately from the side lite?
    Right now it's a door family, with the side lite modeled next to it. I'm thinking I would need to insert a window for the side lite instead of modeling it, correct? But, since the parent family is a door category, would it let me schedule the window as a window?
    3,171
    05:04 AM
    See illustration.
    dzatto's Avatar
    5,236
    04:04 AM
    See illustration.
    Thanks Alf. I wouldn't have rememberd to check the shared box. I think I'm finally starting to think about families half way correctly. lol
    Kingdom of Denmark
    4,245
    11:04 AM
    I┤ve been meaning to test this hierarchy, but have not found the time yet...
    If it works, I can get rid of the "Door" and "Window" icon in the UI, AND there will be no more double (sometimes triple) tagging when using "Tag all not tagged"
    dzatto's Avatar
    5,236
    04:04 AM
    Have you had a chance to test that out yet? I'm redoing my doors............again. lol I'm curious to see if this worked. I can test it if you haven't yet.
    10,508
    04:04 AM
    What is there to test? It works fine, as long as you dont mind that the sub elements respond graphically to changes that get made to Generic models, and not Doors and Windows. If theyre Shared, they respond to their actual category. If theyre not Shared, the entire system sucks because you have to have them loaded in every door.
    Thats why (in the set of doors i uploaded) they are ALL door families. We dont get triple tagging, since there is a pair of filters the users can just uncheck to turn off Panels and Frames (what we use for sidelights). And, they all still respond as doors.
    dzatto's Avatar
    5,236
    04:04 AM
    Okay, that makes sense. But what if I need my side lites to tag as windows?
    This is basic, but I'm trying to nest a window into my door but I'm stuck on how to get the windows width and height parameters to link to the doors width and heigth. I can't figure it out. I had families. lol
    10,508
    04:04 AM
    If theyre shared, you can only nest instance parameters. Shared Families Type parameters are controlled directly from the project, so they cannot be tied to the door.
    dzatto's Avatar
    5,236
    04:04 AM
    Now you tell me. LOL
    Just to make sure I'm doing this correctly. Does it have to be a shared parameter or a family parameter?
    In the door family, do I have to create new instance families as well? The width and height paramters in the family template that you cannot edit are type paramaters, right?
    dzatto's Avatar
    5,236
    04:04 AM
    Okay, I think I got it now. I was trying to link them in the window family for some reason. I selected the window in the host family and, since they are now instance parameters, I have the option to the associate family paramters and link them. So far so good.
  1. Flush Side Duct Mounted Grilles
    By W.Neuok in forum MEP - Family Creation
    Last Post: May 29th, 2013, 03:47 PM
  2. Opaque Glass in Perspective?
    By Darken Rahl in forum Rendering and Gallery
    Last Post: May 28th, 2011, 06:02 PM
  3. Modeling a rail car track down the side of a mountain.
    By petergiampaoli in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2011, 04:48 PM
  4. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 05:02 PM
  5. 2D Transparent Glass
    By mark b in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 07:15 PM
