Thread: Fatal error: Windows has run out of memory
    December 5, 2015
    8
    01:53 PM
    i was loading a very complex conceptual mass into an empty project.
    the mass consists of multiple irregularly curved surfaces with applied custom pattern (rhomboid) family used as curtain paneling. the panels were applied with glass material.
    upon loading it to the project, i had that error.
    i was surprised since the model is fairly small and really just a massing, no architectural articulations and families yet and because i had confidence with the specs of my pc:
    i7 5820k o'ced to 4.2
    16gb 2400mhz ddr4 ram
    gtx 980ti.
    does that mean i'm running out of ram?
    hoping for your enlightenment on this, thanks!
    11,017
    11:53 PM
    How long did it take trying to load? Did you monitor the task manager while loading the family? Is the computer genuinely using all the memory? Can you post the file?
    December 5, 2015
    8
    01:53 PM
    yeah, it took too long. maybe about 20 minutes (loading of family into the project)
    i have only checked the task manager when the error came up. under the memory column , it says im using 99%. however upon seeing the row showing revits usage, it's only using 8000+mb, i have 16 gb but why does it only used 8gb+ and it registers 99% usage. i checked my system properties and it registers the 16gb. also the bios detects the 16gb ram. is there anyway to verify this?
    Rotterdam, South Holland
    3,071
    05:53 AM
    Barry13,
    what happens if you reboot the machine then load that conceptual mass very first thing? If you are using 99% of RAM but Revit is only using half of that, you could have a memory leak somewhere, perhaps not even related to Revit. If, for example, Internet Explorer or Outlook had a memory leak and was "using" 50% itself, it would cripple Revit when you tried something memory heavy.
    Also, take a look at your Swap File settings. If you have no swap file it can cause you to run out of RAM much earlier because programs with memory leaks or that haven't done their garbage collection yet are still holding RAM, and that unreleased but unused resourced can't be swapped to disk to free up RAM for active processes.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    08:53 PM
    Try clearing out your C:\Temp file too...
  1. Error fatal editando blends
    By Thasso00 in forum Foro Espaol
    Last Post: March 5th, 2014, 07:02 PM
  2. Marvin Windows and Cant Make Type Error
    By DaneHitchins in forum Architecture and General Revit Questions
    Last Post: January 18th, 2014, 10:53 AM
  3. Memory timing
    By cellophane in forum Hardware and Infrastructure
    Last Post: May 2nd, 2012, 08:30 PM
  4. shared memory
    By btrusty in forum Hardware and Infrastructure
    Last Post: April 16th, 2011, 05:27 AM
  5. Exporting DWG and DXF causing fatal error
    By rsloyer in forum Architecture and General Revit Questions
    Last Post: December 14th, 2010, 01:43 PM
