Thread: Rigid Slab & Foundation Insulation
    6,205
    05:36 PM
    How are people handling rigid slab insulation? If I use a wall I can use a wall sweep and it is easy but if I use a structural foundation I can't use a wall sweep and would have to use an in-place model. Is one way better than the other from an architectural standpoint (str isn't in Revit yet )
    April 12, 2011
    Chicago, IL
    534
    04:36 PM
    Slab insulation or foundation wall insulation? Foundation insulation could just be a wall itself. I usually make a separate floor type for insulated slabs which makes it easy to add a filter to show those areas in plan. This gets tricky with sloped floors though.
    6,205
    05:36 PM
    Quote Originally Posted by chris.macko View Post
    Sorry - foundation wall insulation. I'm brain dead today
    May 18, 2011
    Calgary, AB
    410
    03:36 PM
    I usually only showed vertical on the outside using a wall. Floors and walls are probably the better way.
    You could throw generic models in there as a contender for it's joinablity and being able to make it parametric.
    Don't have to many choices to pick from.
    2,652
    02:36 PM
    What about using a wall for the vertical insulation and a sweep on that wall for the horizontal?
    Not quite as automated but might be better in the long run when conditions vary.
    St. Louis, MO
    1,954
    04:36 PM
    Another possibility--Slab Edge on the floor for the under-slab insulation.
    Thick Concrete Wall for Foundation, with a sweep for foundation/vertical insulation.
  1. Raft Foundation inconstant slab thickness
    By azsaqib in forum Structure - General Questions
    Last Post: December 23rd, 2014, 02:59 AM
  2. Curved and sloped foundation slab
    By swatson in forum Structure - General Questions
    Last Post: December 19th, 2014, 05:55 PM
  3. Curved and sloping foundation slab
    By swatson in forum Structure - Family Creation
    Last Post: December 18th, 2014, 02:29 PM
  4. Wall and slab foundation
    By Tomcsie in forum Architecture and General Revit Questions
    Last Post: March 11th, 2013, 04:16 PM
  5. Foundation Plans and Slab Edges
    Last Post: February 28th, 2011, 08:47 PM
