Thread: Curtain wall panel
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,116
    03:47 PM
    Curtain wall panel
    Hi all I'm trying to creates a new curtain wall panel (see photo), I'm using adaptive curtain wall but I don't get the results I wantClick image for larger version.
ID:	22380 to have, any suggestions, tnx in advance.
    Member byk3bep's Avatar
    January 30, 2014
    453
    03:47 PM
    Adaptive components are the way to go.
    Wold be nice to know how you are going about this in order to resolve the issue.
    I would make adaptive panel (3 types in this case), load into mass, place one of them on a divided surface, repeat, and swap out the ones you want in order to get the wanted panel distribution.
    I don't know how to make it "random" like it's shown in the picture.
    Anyway seems like a fun exercise, so I'll give it a go during the weekend and post the result later...
    June 21, 2012
    Tours, France
    1,116
    03:47 PM
    Quote Originally Posted by byk3bep View Post
    Hi byk3bep, ant tnx for your time, actually I'm trying to create a 4 point adaptive panel; but I'm not getting the same results as the image, I'm still trying anyway, regards.
    January 30, 2014
    453
    03:47 PM
    Quote Originally Posted by Andres Franco View Post
    ...actually I'm trying to create a 4 point adaptive panel...
    Describe the proces you are using, or better yet show some screenshots
    June 21, 2012
    Tours, France
    1,116
    03:47 PM
    Hi byk3bep, I'm using adaptive panel and I'm creating adaptive points and reference lines as you can see in the image 1, I'm adding non adaptive points and lines trying to obtain the geometry you saw in the first post (which actually was modeled in sketch up), but I don't get the same result because the holes are still changing, I think that I'm almost in the point but I don't figure out what I'm doing wrong, tnx again
ID:	22383 Click image for larger version.
ID:	22384 Click image for larger version.
    January 30, 2014
    453
    03:47 PM
    4 points is not gonna do it.
    Take a look at this
    http://www.revitforum.org/architectu...uted-wall.html
    At the bottom there are link.
    Not being a solution to your problem, the 2nd one describes how to create curved panels. It could prove usefull...
    Search for Zach Kron on youtube. He's the guru.
    On the problem at hand, more a bit later...
    January 30, 2014
    453
    03:47 PM
    It took me more then I initially thought, but that's not a surprise...
    Rather then a detailed explanation, I decided to just upload the family.
    https://www.dropbox.com/s/b15o38m07b...eWall.rvt?dl=0
    Have in mind this is a "cosmetic" panel. Didn't manage to figure out how to parametrize the border width, and the turning radius.
    The panel thickness is a parameter, and just for fun I made them different, as is visible in the attached pictures. This is easy to change, and once the parameters are the same the panels will fit seamlessly.
    If you have any questions, feel free to ask.
    I'm hoping someone will point me to the things I could have done in a better way
Name:	3D View 1.jpg
ID:	22387Click image for larger version.
Name:	3D View 2.jpg
ID:	22388Click image for larger version.
Name:	3D View 3.jpg
ID:	22389Click image for larger version.
Name:	3D View 4.jpg
  1. curtain wall panel tag
    By redmonki in forum Architecture and General Revit Questions
    Last Post: October 16th, 2014, 09:34 AM
  2. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    By Sticky Notes in forum Blog Feeds
    Last Post: June 14th, 2012, 02:45 PM
  3. Question on Curtain Wall Panel
    By thaihoalu in forum Architecture - Family Creation
    Last Post: January 1st, 2012, 02:16 AM
  4. Curtain Wall Panel
    By Drew in forum Architecture and General Revit Questions
    Last Post: November 27th, 2011, 09:05 PM
