Thread: 2011: Should the ambient occlusion pass show up in plots?
    December 12, 2010
    Paradise, CA
    52
    04:23 PM
    Question 2011: Should the ambient occlusion pass show up in plots?
    I've got several views that are set to shaded-with-edges and have ambient occlusion turned on. When I plot these views, either directly to the plotter or to PDF files, the ambient occlusion effect does not show up.
    Is this just something weird with my setup or is this a "feature"?
    Chris
    Nantes, France
    1,380
    01:23 AM
    I've read some time ago that ambient occlusion won't print if image width is set to more than 2000 pixel.
    check here
    4,551
    11:23 PM
    check here
    Julien, exporting indeed does sometimes work (on smaller sizes). But that wasn't the question: will it PRINT? The answer to that question is no, it won't. You can't print AO to pdf or directly on plotter. The only workaround is creating an image by export and reimporting this. Also you can save a view as an image from within revit and place this on a sheet. This should work also. (again, only for sizes smaller than 2000 pixel).
    December 12, 2010
    Paradise, CA
    52
    04:23 PM
    Thanks, guys. You've answered my question.
    January 12, 2011
    London, UK
    562
    12:23 AM
    Hi.
    1. Any updates on this 2000 pixel limit on ambient occlusion export ? Does it still apply ?
    2. Is there a 'live' work-around the export image method ? Once the image is exported, it is 'dead', any way to have an image that will update itself without the user needing to re-export and re-insert into sheets every time ?
    Thanks in advance, Kamran.
    Nantes, France
    1,380
    01:23 AM
    1- have read somewhere it is fixed in 2013
    2- use raytrace mode in 2013
    January 12, 2011
    London, UK
    562
    12:23 AM
    Oh, ok. Thanks. Will try it out.
  1. Show Off Your Workspace!!
    By dzatto in forum Out There
    Last Post: August 20th, 2013, 10:23 PM
  2. Show Off Your Interior / Exterior Spaces
    Last Post: May 4th, 2011, 03:13 PM
  3. 2011: show demolition in all previous phases?
    Last Post: April 30th, 2011, 01:23 PM
  4. Win a Free Pass to AU 2011 in Las Vegas
    By Munkholm in forum Out There
    Last Post: March 31st, 2011, 03:56 AM
  5. Show me your Blog!
    Last Post: March 18th, 2011, 07:44 AM
