Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Topography from an AutoCAD file with points
    June 30, 2011
    6
    09:13 AM
    I have a client supplied .dwg of the site using surveyed geodetic locations as points. These points have z values but Revit can't seem to read them.
    I am new to the site, so if there are topics on this issue, please point me in the right direction. Thanks for your time.
    ~Fubar
    June 30, 2011
    14
    01:13 PM
    At site and massing, you have the option: Create Toposurface-> Create From Import - Points or dwg file..
    Make sure the scale is ok...
    June 30, 2011
    6
    09:13 AM
    i adjusted scales, and followed your steps. I click the imported autocad file, then finish surface. command goes through, but no surface...
    Kingdom of Denmark
    4,236
    05:13 PM
    The problem is that you only have the points I think... Revit is expecting contour lines in the imported DWG (with z elevations).
    So either add the contour lines to the dwg before you import it, or try to get the existing points exported to a comma separated .txt or .csv file with (x, y, z) information for each point, and then use the points file to create the toposurface in Revit.
    Not sure if the newer versions of AutoCAD can export a points file, but if not, there┤s a bunch of different lisp routines floating around on the internet from the old days.
    June 30, 2011
    6
    09:13 AM
    thanks for your quick feedback! I have figured out how I can export the data as a CSV file but when I use that for the Revit topograpthy it tells me there is no points... but I exported over 1000...
    also, when I import it into revit it asks me scale but the scale is decimal feet? etc? which should I pick, it's in X'-X"....
    June 15, 2011
    13
    11:13 AM
    If your client is using AutoCAD Civil 3D, he can model a surface using the points and then EXTRACT contour lines (just polylines with elevations) - THIS is the part of the .dwg that will talk to Revit I believe.
    3,153
    11:13 AM
    Quote Originally Posted by fubar_69 View Post
    Check if the file is in the proper format. The format is this:
    x,y, and z coordinates of first endpoint of line 1
    x,y, and z coordinates of second endpoint of line 1
    x,y, and z coordinates of first endpoint of line 2
    x,y, and z coordinates of second endpoint of line 2
    etc....
    Example:
    813.91,-440.24,-24.00
    813.91,841.78,-24.00
    -493.23,-446.82,-24.00
    etc...
    Save as .csv
    Member feio's Avatar
    Decadent Lisbon
    450
    04:13 PM
    In autocad, there is a data extraction tool, where you can take off the coordinates (in this case, of points).
    The output can be a text file, ready for revit topography.
    St. Louis, MO
    1,954
    10:13 AM
    Feio,
    Can you explain a bit further--how to use the text file and make a topo in Revit?
    3,153
    11:13 AM
    Quote Originally Posted by cliff collins View Post
    Feio,
    Hello, sir, you look very elegant in your new Avatar.
    Check this image, from my old posts in Augi. You need to begin from the Table command in AutoCAD.
  1. topography surface created by imported file not visible in 3D view
    By anjata in forum Architecture and General Revit Questions
    Last Post: February 12th, 2012, 12:55 AM
  2. Help AutoCAD bulding to 3d model in Revit
    By dlggnation in forum Architecture and General Revit Questions
    Last Post: April 20th, 2011, 08:23 AM
  3. Export to Autocad
    Last Post: April 1st, 2011, 09:27 PM
  4. Reputation points?
    By Dave Jones in forum Forum Suggestions and Feedback
    Last Post: January 16th, 2011, 03:01 PM
