Results 1 to 10 of 14
Thread: Floor thickness issue
    Member byk3bep's Avatar
    January 30, 2014
    450
    10:57 AM
    I created the roof of the building using the floor command.
    The problem is that the specified thickness of the floor (20cm) differs then the one that is shown in section. I'm guessing that it has to do with the slope angle, and that the floor thickness is in the global z direction.
    Is there a way to correct this, or am I going about this the wrong way. What is the right way?
    Thx for the help, it's much appreciated
    6,229
    04:57 AM
    How did you get your slope? Did you use a slope on your floor or did you use modify sub-elements? If you just apply a slope the thickness will stay constant across the object, if you use modify sub-elements it will distort.
    Why did you use a floor instead of a roof or multiple roofs?
    3,171
    04:57 AM
    That is a known consequence of editing points on a roof or slab. Revit usually issues a warning about it:
    "Thickness of this Roof may be slightly inaccurate due to extreme Shape Editing. Dimensions to this element in sections and details may not accurately indicate the Thickness shown in Type Properties."
    Maybe that roof could be done in other simpler ways, since it is not complex geometry.
    January 30, 2014
    450
    10:57 AM
    Yep, it's a floor with modified sub elements
    What aproach would you take in this case?
    3,171
    04:57 AM
    I would create a roof type and a wall type with the same materials and thicknesses. A mass with the shape of the slanted walls. Then, walls by face, then a simple roof by footprint for the top. Now you can have proper thickness of materials for the sections.
    January 30, 2014
    450
    10:57 AM
    Thx for your help guys
    Cheers
    June 7, 2018
    4
    01:57 AM
    How would you go about keeping the thickness consistent if roof has a complex geometry (see attached image)? any work around that would keep the roof points and lines editable and would give the roof a consistent thickness? In this case, the roof is modeled with footprint, modified by sub elements, cut with vertical opening and points at split lines intersection define the elevations.
    2,658
    01:57 AM
    Model each facet individually and slope each as appropriate with a slope arrow. Clean up with voids, etc. No easy button if you need to maintain thickness.
    June 7, 2018
    4
    01:57 AM
    Thanks for your response. I understand. This is what I was afraid of. In this case since the roof is quite large and elevations need to be more accessible and adjustable, this wouldn't be as efficient.
    3,171
    04:57 AM
    Maybe this needs to be modeled A) in a generic model adaptive template, using points, reference lines, individual surfaces and two reference planes as hosts for the points. Once this is loaded into a project, B) you create roof(s) by face. These roofs will have a constant thickness. To edit the roof, you edit the location of the points in the family, or the elevation of the hosts reference planes, or create void forms in the family, reload, and update the roof by face.
    Attached Thumbnails Attached Thumbnails 2019-01-14_13-43-44.jpg   2019-01-14_13-43-13.jpg
  1. Floor tag: thickness ....finally
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: July 8th, 2017, 05:12 AM
  2. Floor surface pattern thickness overrides by object style when demolished
    By ikinks in forum Architecture and General Revit Questions
    Last Post: March 16th, 2015, 07:25 AM
  3. Curtain Wall Thickness Issue
    By gurpsb in forum Architecture and General Revit Questions
    Last Post: November 17th, 2014, 02:10 AM
  4. Structural floor issue
    By Andres Franco in forum Structure - General Questions
    Last Post: April 19th, 2013, 10:02 PM
