Results 1 to 10 of 10
Thread: Manufacturer Part Numbers?
    March 5, 2015
    5
    09:45 AM
    Hi. I'm trying to create manufacturer specific pipe fitting libraries. Is it possible to add manufacturer part numbers to individual sizes of components? E.G. I have made an elbow family using lookup tables, but I can't see how I can add the unique part numbers to each individual size of elbow. Any ideas?
    1,402
    10:45 AM
    2 options.
    1. Put the part numbers in the lookup table, in the correct row with the diameters. Then in the family make an instance parameter for part number (Shared parameter if you want to tag/schedule it) and then use; =size_lookup(Lookup Table Name, "Column with part number", Size, Value if not found) in the formula to get the part number. (Or something like that, check the exact syntax).
    2. Use an If formula; =If(Size > X, "Part Number X", If(Size > Z, "Part Number Z", If(...... and so on. (Write it in notepad with tabs and line breaks, they disappear when you paste to revit).
    January 17, 2011
    2,062
    03:45 AM
    Reeeeeally? Tip of the century right here!! I wanna try this in Notepad++....
    1,402
    10:45 AM
    ((It beats trying to write 20 if statements inside each other in a tiny text bo)...unexpected end of statement
    March 5, 2015
    5
    09:45 AM
    Thanks Joseph, much appreciated.
    Killian
    March 5, 2015
    5
    09:45 AM
    Hi, I'm finally getting around to looking at this again. I got it to work if the manufacturer part number is numberical only, using a number type shared parameter using the following formula =size_lookup(Lookup Table Name, "Part_Code", 0, Nominal Diameter / 1).
    If the Part number has any letters in it, it won't work with that formula, so I tried creating a text type shared parameter, but then I can't get the formula to work, it just says "Invalid Input". Any ideas please? Thanks
    August 7, 2015
    USA
    11
    01:45 AM
    Quote Originally Posted by Kilian View Post
    Did you ever get it to work?
    this was my solution; I created a Text instance parameter with the following formula
    if(and(D1 = 1/2", D2 = 1/2", Angle = 90░), "9801-005", if(and(D1 = 3/4", D2 = 3/4", Angle = 90░), "9801-007",if(and(XX = size, XX2 = size, XX? = size/angle), "Partnumber","0")))
    anything you want to be "Text" actually has to be surrounded by Quotes, even your "false" statement has to be surrounded by Quotes. replace my Variables with yours and continue added the sizes. i set up a template at the end. XX? may not be needed depended on your constraints, everything in red can be deleted if not needed. don't forget to add a parenthesis at the end for every additional if(and( Statment
    March 5, 2015
    5
    09:45 AM
    Hi, yes I got it to work using the formula like you suggested. It would be great if we could add a text column for part numbers into the lookup table instead of typing all the part numbers into a formula - but hey it works so thats good. I have added two shared parameters to my parts, one is the Manufacturer Part Number (using the formula & shared text parameter), the other is our company order code (using the lookup table and a Shared number parameter). I just have one question, how do I stop it adding the decimal place and all the zero's?
    Thanks for the help guys.
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    219
    02:45 AM
    In your project schedules you can change your unit formatting. So I would un-check "use default settings" and change my number units to fixed. This allows you to change your rounding to however many decimal places you want.
Name:	Unit formatting.PNG
    March 5, 2015
    5
    09:45 AM
    Thanks Evan
  1. Any exemplary manufacturer-produced lighting families?
    By hywd6545 in forum Architecture - Family Creation
    Last Post: February 26th, 2014, 05:17 PM
  2. Manufacturer Content
    Last Post: October 4th, 2013, 02:03 PM
  3. Manufacturer Rage
    By thewrz in forum MEP - Family Creation
    Last Post: February 3rd, 2012, 04:10 AM
  4. Manufacturer Lights, IES Files, Problem
    By rpmarchitecture in forum Rendering and Gallery
    Last Post: December 31st, 2011, 11:44 PM
