Thread: Detail Item Family Label Param
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    02:26 AM
    How do I add a DTL item family label and only get the options for the DTL item I want available as an option and not all of the Nested Families in the file???
    ie- I added a label to the screw connection at the top of my soffit stud... when I inset this family to a file the Label parameter shows all of the nested families in the file as an option and I only want to include fasteners (lvf, sms, screw anchor, or none)
Name:	family label param.....png
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,522
    07:26 PM
    Any family of the same category in the family (or that is shared in the project environment ) will show as an option. If you only have a couple choices just give each one a visibility parameter and control with an integer (if you want only one option chosen)
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    438
    01:26 PM
    Agreed. The Detail Item is the more clever way to go, but you do get unwanted options in your menu selection. For this reason I also use visibility parameters as it is much neater and easier for users to understand.
  1. Movable Label Annotation in a Detail Item Family
    By SamHenderson27 in forum Structure - Family Creation
    Last Post: December 15th, 2019, 09:22 AM
  2. Detail Item Family
    By ecraider in forum Architecture - Family Creation
    Last Post: January 6th, 2015, 07:11 PM
  3. Detail Item Not Flexing in Family
    By Revitista in forum Architecture - Family Creation
    Last Post: March 19th, 2014, 02:17 AM
    Last Post: January 29th, 2014, 02:15 AM
  5. Titleblock vs Detail Item
    By jsnyder in forum Architecture and General Revit Questions
    Last Post: February 8th, 2011, 11:48 PM
