Thread: Simple drain pan family
    March 6, 2013
    122
    02:26 PM
    Okay so I am trying to make a family for a drain pan. What I did was make an extrusion and put parameters on it for width and length. Then make a void extrusion on top, about 1/2" shorter on each side. I controlled the width and length of the void extrusion with a formula, essentially saying Inner length= length-1"
    When I load the family in the width side of the family works fine. If I increase the width the void width acts accordingly. However, when I increase the length part of the family, the length of the extrusion extends on one side and the length of the void extrusion on the other side. I tried to constrain them to the center reference place by using EQ but then it says that the family is over-constrained. Can you please advise on how to solve this?
    I have attached the family.
    2,658
    01:26 PM
    You'll always better off creating bones (reference planes/lines) before skin (geometry).
    Revised family should work...
    March 6, 2013
    122
    02:26 PM
    The revised family works flawlessly. Thanks a lot.
    I will keep the reference planes in mind next time I am creating a family
  1. Simple Plasterboard Type Family
    By Jock in forum Architecture - Family Creation
    Last Post: January 9th, 2014, 10:16 AM
  2. Simple modelling of drain
    By DeanB72 in forum Structure - Family Creation
    Last Post: January 30th, 2013, 03:18 PM
  3. Problem on simple family ! Help me
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 6th, 2011, 08:38 PM
  4. Simple Family - Concrete hob or upstand
    By adrianc in forum Structure - Family Creation
    Last Post: September 28th, 2011, 06:13 AM
  5. Simple (i hope ) family Issue
    Last Post: September 20th, 2011, 08:18 AM
