Thread: Type's parameter cannot recursively point to the type itself?
    Junior Member jeeenyuss's Avatar
    February 17, 2014
    St. Louis, MO
    30
    12:36 AM
    I have created a family. It is quite a complex family as far as the ones that I have created. It seems fine while I'm building it. I load it into my project. I duplicate a wall, name it, go to change the Curtain Panel Value, and when I do, it says "Type's parameter cannot recursively point to the type itself" I have no idea what that means. I guess there is a problem with the family that I have created but I have no idea what it could be. What should I do?
    6,205
    01:36 AM
    Can you post the family and/or a project with only the elements in question?
    March 6, 2015
    Ukraine
    7
    05:36 AM
ID:	21348I have the same problem but with the curtain wall. I Have the same name in the Type of curtain wall and whant chouse the panel with the same name. And Revit whrite the same problem what was desribed abowe.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,474
    11:36 PM
    Quote Originally Posted by Russik View Post
    It looks to me like your problem is you are choosing the same wall you are editing as the default panel (wall types can be used as a panel in curtain walls). Revit gets into a loop trying to process that, because you are telling it that the default panel type for the wall is the wall you are in the process of editing. The solution would be to choose any other wall or panel type. Perhaps you were trying to choose the same panel type as was used in the plaster stucco white wall? If not you can duplicate that wall and set the duplicate as a default, or probably can unlock the default panel and manually replace the curtain panel with the same wall type.
    March 6, 2015
    Ukraine
    7
    05:36 AM
    Everything is clear, thanks.
    Last Post: August 26th, 2013, 07:45 AM
  2. Including instance parameter in type parameter formula
    By sabari2504 in forum Architecture - Family Creation
    Last Post: August 12th, 2013, 02:54 PM
  3. Revit OpEd: Family Type as Type Catalog Flag
    Last Post: April 11th, 2013, 03:15 PM
  4. select by parameter? curtain wall panels' materials by parameter, by type or family?
    Last Post: January 24th, 2013, 02:20 PM
  5. NOOB question: delete callout type and section type?
    Last Post: July 31st, 2012, 01:28 AM
