Thread: Create a dimension style with a default text suffix
    John_C
    Guest
    Yet again, Revit has succeeded in confounding me when it comes to something that should be easy-peasy.
    What I want is to create a dimension style that will give me a dimension rounded to the nearest 10mm (that's easy), but I also want the style to apply a default suffix of COS (check/confirm on site).
    Any suggestions, other than applying the suffix once the dimensions have been placed ...
    2,800
    11:23 AM
    You're out of luck unless you can make Alternate Units work for you. They allow prefix and suffix to be attached but not the main units display. Does it make sense? Not necessarily but that's just the way it goes...
    John_C
    Guest
    ... Does it make sense? ...
    In the context of your explanation, yes it makes perfect sense, thanks ...
    It the context of ludicrous constraints being imposed on the way that we are allowed to annotate our models ...
  1. Altering the default text of the Color Fill Legend
    Last Post: December 15th, 2013, 06:11 PM
  2. Modify dimension prefix/suffix
    By alexo4141 in forum Third party Add-Ins, API and R&D
    Last Post: November 4th, 2013, 11:51 PM
  3. Changing Tag Text Style
    Last Post: November 29th, 2012, 03:08 PM
  4. Default dim style
    By Defiant1 in forum Structure - General Questions
    Last Post: September 16th, 2012, 03:01 PM
  5. Custom Dimension Style
    By zecks in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2011, 02:27 PM
