Results 1 to 10 of 10
Thread: Linked file cannot be reloaded...
    August 19, 2011
    42
    04:12 PM
    because it is loaded into another open document".
    i'm getting this message though the linked file is an overlay and isn't open in any other file it's linked into; it's only open by itself, which shouldn't qualify as "another open document". i haven't had a problem reloading the link in the past with it open but now it wants me to close the open file in order to reload. Can anyone tell me what's going on here? Thanks much
    3,046
    03:12 PM
    Do you have any 3rd party add-ins installed?
    There's a bug in the API for any program that allows you to dock the add-in's window.
    Even if you close the Linked file, the API thinks it's still open and can cause the kind of problems you describe.
    This applies to any add-in that uses the dockable window, but the one I've seen it in the most is the
    About the only program I'm aware of that uses the dockable framework is the Kiwi Codes Family Browser.
    But its a bug in the API, not in KCFB.
    Coeur d Alene, ID
    4,824
    01:12 PM
    Revit knows that the file is open for editing, so it wont load it. Save the project as a workshared project and you won't have to deal with that message.
    August 19, 2011
    42
    04:12 PM
    Thanks for the responses.
    i have one add-on, called Selection Master by Revolution Design. To date i haven't had problems with running it but maybe things have changed.
    The project is already workshared, so that can't be the problem.
    Coeur d Alene, ID
    4,824
    01:12 PM
    Quote Originally Posted by candystink View Post
    If it's workshared then it shouldn't be open by itself....it should have a local file....So if someone is working in the Central File they need to get out of it. But it could have become corrupted and you may need to perform an Audit/Detach from Central and resave as another central file.
    August 19, 2011
    42
    04:12 PM
    Thanks Michael.
    The file isn't open by itself, so i may have to do what you suggest and detach/resave.
    August 19, 2011
    42
    04:12 PM
    i audited the file and detached from central and resaved, but still i get the message. Oddly, it seems that the file reloaded despite the message. i smell a pig oinking..
    August 19, 2011
    42
    04:12 PM
    Ok i think i'm getting closer to the answer, but i'm still confused. It seems that because i have another file linked into the file i'm trying to reload, and that's defined as an Attachment, the file won't reload. This seems strange, as if the linked file as attachment is considered to be a file my reload file is linked in to. Does this make sense to anyone?
    March 18, 2013
    09:12 PM
    I came across the same problem.
    It's caused by, it seems, using different network paths. For example, I use a drive letter path for my Revit file e.g. P:\ and the other person uses a shortcut. //file path.
    The solution is to ensure you are both using the same network path to access your Revit models.
    May 7, 2014
    62
    04:12 PM
    I have created three projects. Project 1, 2, 3. There is nothing in the files, and work-sharing has been enabled. I linked them by auto center-to-center. I get the same warning message...
    I have another set of three projects which are central models, linked by a shared coordinates file, and still get the same message...
    Another set of projects that are not central models, linked by shared coordinates, same message..
    Another set of projects that are not central models, and linked by auto center-to-center...
    I have solved it before, but can't remember, and can't solve this for the life of me....
  1. Sheets within a linked file
    By DGoffron in forum Architecture and General Revit Questions
    Last Post: December 20th, 2013, 03:38 PM
  2. Displacement and linked file
    Last Post: September 11th, 2013, 07:01 AM
  3. Turn off 1 linked file i
    Last Post: March 11th, 2013, 12:19 PM
  4. Architects file linked into Interiors File
    Last Post: July 2nd, 2012, 09:25 PM
  5. Linked File Position
    By Steve Faust in forum Third party Add-Ins, API and R&D
    Last Post: June 2nd, 2011, 06:35 PM
