Thread: Section References Broken?
    Auckland, New Zealand
    611
    03:50 AM
    Okay,
    Can someone confirm for me that I'm not going mad.
    I have 2 main detail section types, one that references a view on a sheet and one that reference a whole sheet. (the visibility of the 'detail' label is the only difference)
    When I draw a detail section the selected type is used as expected.
    When I check 'Reference Other View' Revit uses a 'default' section head (in this case my 'sheet' reference)??
    This is a bug, or I have gone more crazy than usual!!?!
    February 17, 2011
    Raleigh, NC
    193
    11:50 AM
    When you check "Reference Other View" it will use the section head set in the view that you are referencing. Does that help?
    611
    03:50 AM
    Indeed...
    That is a bit silly of me! Its been a while since I had to document (not that it shows...)
    Thanks for the help
  1. Circular chain of references?!?!?!
    Last Post: January 18th, 2018, 09:59 PM
  2. Tags losing references
    Last Post: February 5th, 2014, 02:34 PM
  3. Revit OpEd: View References
    Last Post: August 22nd, 2013, 06:45 AM
  4. References same view
    By nsoufiani in forum Architecture and General Revit Questions
    Last Post: December 19th, 2012, 12:37 PM
  5. Revit OpEd: Measure Between Two References
    Last Post: June 13th, 2012, 06:15 AM
