Thread: Shared Parameter Category
    Moderator Drew's Avatar
    Perth, Western Australia
    691
    07:35 AM
    Hi All,
    I am creating a title block for a new client and I have created some new Shared Parameter labels for the project information and sheet information.
    I have most of them working, however there are some that I want to add to the "Drawing Sheet" category in the project, however when I load the shared parameters into the project, the Drawing Category isn't listed.
    Any ideas why?
    3,231
    07:35 PM
    There is no "Drawing Sheet" category. There is a "Sheets" category, instead, which is available only when the kind of parameter is "instance"; if you try to change the kind to "type", then "Sheets" disappears from the list. Maybe you're trying to use "type" parameters for sheets.
    691
    07:35 AM
    Thanks Alfredo.
    I thought I tried both and it wasn't available. I will have another look at it.
    When you look through the "help" file it definitely says "drawing sheets" is a category..very wierd
    3,231
    07:35 PM
    In the project, create a Project parameter, browse for a shared parameter, select "instance", and "Sheets" will be on the list of available categories.
    I think the name "Drawing Sheets" was used in previous versions of Revit, and that's probably why the help documents refer to that term.
    11:35 PM
    Yep, until 2010 they were called Drawing Sheets...
  1. Area Type parameter
    By gaby424 in forum Architecture - Family Creation
    Last Post: May 8th, 2011, 12:46 PM
  2. Filter by Shared Parameter?
    Last Post: March 28th, 2011, 05:02 PM
  3. Name category of views
    By Severnik in forum Architecture and General Revit Questions
    Last Post: March 12th, 2011, 12:13 AM
  4. Another Parameter Topic
    Last Post: January 30th, 2011, 12:28 AM
  5. Convert Project Parameter to Shared Parameter
    Last Post: January 5th, 2011, 07:35 AM
