Thread: Shared Parameters or Project Parameters?
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    988
    04:25 PM
    I have created a boat load of Shared Parameters but I wonder where to draw the line at doing to much of a good thing and turning my firms template into a bloated example of what not to do.
    Can anyone provide a Parameter methodology that they employ for their firm?
    Chuck
    I mistakenly referred to Instance parameters when I meant Shared,...
    Last edited by dzatto; November 7th, 2013 at 01:17 PM. Reason: I mistakenly used the term 'Instance Parameter' rather than 'Shared'
    2,645
    10:25 AM
    Quote Originally Posted by Charles Karl View Post
    Chuck
    Type is exactly that, a type of family. Typically an instance parameter is used to give different functionality to a single instance of a family type. Your choice should be based on the end use of the parameter.
    While this blog post is a few years old it is a very good explanation of the differences and gives real world examples. Take note of what is being said near the end of the post about file size. HTH
    December 6, 2011
    Fairbanks, Alaska
    988
    04:25 PM
    I appologize for the missunderstanding, however, Shared and Project parameters are what I meant to compare
    3,153
    08:25 PM
    I apologize for the misunderstanding, however, Shared and Project parameters are what I meant to compare
    Project parameters are custom properties that you add to categories in a project, by type or instance. When you create these custom properties, you have two options: either project parameters or shared parameters. Use Shared parameters instead of Project parameters if...
    1)... you want those custom properties to be used in tags, (you would need to edit the tag families to add the same shared parameters).
    2)... you want to standardize the definitions of those custom properties through all your projects, using always the same definitions that you define in the shared parameters file.
    Both project parameters and shared parameters can be scheduled. If you just want to add a custom property to a schedule, without needing those two points that I mentioned above, simply use the "Add parameter" button and create the property as project parameter.
    I hope it helps.
    Member feio's Avatar
    Decadent Lisbon
    450
    01:25 AM
    Digging a bit deeper, standard (project & family) parameters are indexed with an 32 bit integer, while shared parameters are indexed with a Guid (that you can see in the SP text file).
    That huge difference is what allows tying those shared parameters from family instances to the main model and the tags without the risk of conflicting with other parameters.
    Appart from that, and with an API perspective, all parameters are the same. Their difference is only its Definition property that can host different classes (InternalDefinition or ExternalDefinition). Try to think of it like a DNA sequence change that triggers different behaviours.
    "OMG I killed Revit"
    dzatto's Avatar
    5,234
    07:25 PM
    Charles,
    I revised the title to "shared" instead of "instance" to help with the search functions of the site. Hope you don't mind.
    2,645
    10:25 AM
    Ask a better question, get a better answer
  1. Setting instance parameters
    By bshara in forum Third party Add-Ins, API and R&D
    Last Post: June 8th, 2013, 09:09 PM
  2. Instance parameters in Arrays
    By KWilkinson in forum Architecture and General Revit Questions
    Last Post: February 18th, 2013, 08:26 PM
  3. Match properties for instance parameters?
    By jgu in forum Architecture and General Revit Questions
    Last Post: December 18th, 2012, 10:04 PM
  4. Groups (again!) & Instance parameters (again?)
    Last Post: December 15th, 2011, 04:34 PM
  5. Shared Nested Family (Instance) Parameters not available in project?
    Last Post: August 27th, 2011, 12:39 PM
