Results 1 to 10 of 16
Thread: Silver Bullet Key Plan?
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    996
    01:49 PM
    Has anyone found the best way to create a key plan with the least amount of work? I have been though more than one way of constructing a usable key plan, but it seems that no matter what direction I take, there are too many steps that are not quite 'Best Practice' in my estimation.
    Any thoughts are appreciated,...
    Member aperte's Avatar
    69
    02:49 PM
    Our most useable output has been through this process:
    a) export a plan to dwg
    b) insert plan dwg into a Generic Annotation (scale to anticipated use)
    c) Create outlines and filled regions for building zones
    d) Add visibility controls over filled regions corresponding to Type for each zone
    e) Team decides whether to embed into project specific Titleblocks (type per building zone - works best for large projects)
    or
    e) Add as a symbol to Legends (separate legend per building zone)
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    677
    02:49 PM
    Quote Originally Posted by aperte View Post
    or
    Then remove the .dwg I hope!!!
    4,415
    10:49 PM
    I make a generic annotation family that I nest into sheets and control zone visibility parametrically. I might also place it on views. One thing to save yourself a world of pain is taking a very abstract approach to "drawing" the building - omit as much as you can whilst still conveying the geometric, spatial shape of the building - both in plan and section. You will find that the line-length limit will actually force you to do this anyway with projects that need a v.large scale for the key plan.
    That said, I would do away with them altogether if I could.
    December 6, 2011
    Fairbanks, Alaska
    996
    01:49 PM
    or
    This is actually the method that I use currently,...it is effective, but time consuming and not very 'BIM'.
    I am wondering if an automated approach can be employed.
    69
    02:49 PM
    We initially tried with Site Plans, then Area Plans, all had serious frustrations. The Generic Annotation method takes a bit of time, and does NOT update to major changes to the building geometry, but once it's done its streamlined and very easy to use throughout hundreds of pages of documentation. That was the tipping point issue.
    December 6, 2011
    Fairbanks, Alaska
    996
    01:49 PM
    Thanks for your input,...I will continue with this method
    December 17, 2010
    Los Angeles
    677
    02:49 PM
    As SnowyWeston mentioned, abstracted key plans are the way to go, no need (in my opinion) to invoke any .dwg export or import in most every case.
    One can draw a simplified key plan easily enough that relates to the bldg shape(s) and unless there is a complete redesign there is (usually) no need to make small adjustments...
    I do though disagree with some of the comments herein, relating to difficulty or time these take: It does not take too long to create these, let alone adjust them when needed.
    Once setup on a titleblock family those can remain in the office standard titleblock, then just be modified per project, to relate to the current project's shape and 'zone' break-ups.
    December 6, 2011
    Fairbanks, Alaska
    996
    01:49 PM
    Quote Originally Posted by JBZ View Post
    Agreed,....the time spent trying to accomplish some sort of BIM connection with a key plan was taking up most of my time. As long as I stay focused on not trying to reinvent the wheel, I move along at a steady pace,...lol.
    Coeur d Alene, ID
    4,850
    02:49 PM
    Would be cool if Revit could create its own "block" of different levels that can be scalable to whatever you wanted.....(It's a feature of Chief Architect...use it for site plans and details/sections since CA sucks for sections and have to be drawn manually)
  1. Area plan as occupancy plan and schedule
    Last Post: February 5th, 2016, 09:16 PM
  2. Family indicating different - Ceiling Plan/Plan
    Last Post: July 24th, 2013, 08:49 AM
  3. Change Floor Plan View to Structural Plan View
    Last Post: August 29th, 2012, 05:10 AM
  4. What to draw first? Floor Plan or Site Plan?
    By WBustos98 in forum Architecture and General Revit Questions
    Last Post: November 30th, 2011, 02:08 AM
