Thread: oops - forgot to slope the steel
    November 28, 2011
    Ontario, Canada
    154
    03:18 AM
    Hello All
    I thought i posted this question previously for another project but I cannot find the post.
    Anyway, I have finished a new project all in steel and silly me forgot to set certain columns to a lower elevation to slope the steel, joist and deck. (architect does not want sloped insulation).
    I need to drop 2 columns and 4 beams by 4" to slope the steel and I was wondering how I can do it so that the joist will adjust automatically and the deck show the slope
    sorry for the newbie question, this is something I was never shown how to do.
    Thanks in advance
    Senior Member alexo4141's Avatar
    May 25, 2011
    QuÚbec, Canada
    548
    03:18 AM
    Unfortunately, there's not a "all-in-one" answer that would solve that issue because it all depends on the way you modeled your steel structure. Assuming your beam systems are set to "3D", they should adjust themselves if you lower the beams they sit on. For the deck, you will have to add a sub-element and set it to the correct elevation.
    Here's a thread I started a while ago about a way to control steel structures when they are very typical (No overhang or continuous beams): http://www.revitforum.org/structure-...structure.html
    HTH
  1. Cold Formed Steel - Steel studs
    Last Post: August 27th, 2013, 12:24 PM
  2. slope
    By sepideh in forum Structure - General Questions
    Last Post: September 18th, 2012, 04:48 PM
  3. Not so smart slope?
    By Bross in forum Structure - General Questions
    Last Post: December 16th, 2011, 10:48 PM
  4. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    Last Post: May 6th, 2011, 08:39 PM
